06-23-2011, 07:30 PM | #1 |
Quarry Creeper Join Date: Apr 2009 Location: columbus
| CKRC 4x4 slash killer kit into a FOFF? Any idea's?
I have a 4x4 slashkiller SC truck built from the CKRC kit. It uses hpi mt2 front, rear and center diffs. and the kit provides the Alum' plate chassis and stiffeners. They can be seen on CKRC's website under shortcourse trucks. It is a badass truck although I am running a brushless motor the size of a redbull can an 4s lipo's. I will have to change the motor as this one eats hardened HD gears like M&M's. Would this independent suspension truck work as a FOFF rig if I lenghten the chassis or do I have to run straight axle's?
06-23-2011, 11:56 PM | #2 |
Quarry Creeper Join Date: Jun 2006 Location: Aurora, CO
If you're not too concerned with scale realism then the independent suspension will actually be more stable on the hills than solid axles.
06-24-2011, 02:42 AM | #3 |
Newbie Join Date: May 2011 Location: fonti del clitunno
Hello, you may post a scan of the frame of your slash? I will try to replicate it by hand. thanks and greetings |
06-24-2011, 11:57 AM | #4 |
| 4x4 slashkiller
It's not a slash. It's a 4x4 slashkiller built from a kit CKRC makes. It uses the front, rear, and center diffs from a HPI nitro MT2. The frame and other parts are provided in the kit. Thanks anyways.
06-24-2011, 01:10 PM | #5 | |
I wanna be Dave Join Date: Aug 2004 Location: san jose
06-24-2011, 04:50 PM | #6 |
| 4x4 slash killer
I have had mine for a couple years now. Thanks.
