01-22-2013, 02:03 PM | #61 |
RCC Addict Join Date: Nov 2010 Location: England
| Re: Version 2.
Well my 8mm delrin turned up, so out to the garage, and after some scribbling on paper i got the skid made. forgot to take a pic before i put the motor and trans on. Just got to make a mount for the esc and receiver. The skid is milled out in the centre 3mm deep to lower the battery more. also the motor and trans mount are recessed 4mm. |
01-30-2013, 05:50 PM | #62 |
| Re: Version 2.
Well i have yet again made a change. I decided the motor mount was going to be a pain to change the pinion easily. I had to order some more parts from America as nothing much that i want is stocked over here. While shopping around this mount from Tekno rc caught my eye. TKR4142X – 42mm V3/V4 Motor Mount (CNC alum, black ano, for Castle/Tekin motors, lightened) | Tekno RC – Excellence in RC Design so ordered one, plus enough parts to build another rear axle, but with 36/14 overdrive to match the front if i use this truck when i use it on flat ground, also the STRC steering linkage for the front. This meant a new skid, so when the delrin turned up i got on with it. Yes i need to clean the machining up, but its not finished yet. There will be another slot 3mm deep for the battery tray which im making a new one a bit narrower to hold the battery better. 8mm thick and machined out to 4mm deep for the transmission and motor.Just enough room to clear the driveshafts. apologies for the bad shots, but was in a rush and didn't have time to get the camera out. this will mean a new top plate has to be made, but hopefully soon. |
02-14-2013, 06:04 AM | #63 |
| It's on wheels!!
Well I finally finshed the skid. I decided to run the front of the skid right up behind the front axle to help it slide over the soft stuff. Drier weather next week and time off work, so hoping for some runs. Hpi 1960kv motor, 22 tooth pinion, 46 tooth spur. Lots of delrin machining and cursing. A few things to tidy such as the rear shock brace to be rounded off, and maybe fit a wing, but not sure yet. also have to check upper link length as the axles sit about 3mm off to one side, but it runs fairly straight. I have stock side panels, but not decided on a colour yet... definitely not black tho. Last edited by M1tch; 02-14-2013 at 07:25 AM. |
02-14-2013, 06:43 AM | #64 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
| Re: Version 2.
WOW,that looks great, nice job. Hope the weather is good to you this weekend. |
02-14-2013, 07:16 AM | #65 |
| Re: Version 2.
Thanks, I'm so glad i got this far with it. the skid was a pain, but in the end worth the effort. Just some fine tuning now i hope.
02-14-2013, 05:31 PM | #66 |
Rock Crawler Join Date: Oct 2011 Location: south of nowhere
| Re: Version 2.
Nice, you got it done Will be waiting for some feed back after you hit the sand.... |
02-14-2013, 05:55 PM | #67 |
| Re: Version 2.
Thanks Hacksaw.. I just weighed it..6 lb, 6 1/2 ounces. i think my old foff was 5lb 10 oz, allow for the heavier motor and battery i don't think thats too bad. i could get some weight off in places, but that after i can get a few runs on it.
02-14-2013, 09:27 PM | #68 |
Rock Crawler Join Date: Feb 2006 Location: sunny acres
| Re: Version 2.
Like that tranny set up. What wheels are those? Gmade?
02-14-2013, 09:32 PM | #69 |
| Re: Version 2.
Your rig should be extremely stable. |
02-15-2013, 01:48 AM | #70 |
| Re: Version 2. Yes, I got them off ebay from this seller. 2.2 Mud BEADLOCK WHEELS AX10 WHEELY KING CR01 Blue 4 items in Nowinghobby store on eBay! |
02-15-2013, 07:05 AM | #71 |
| Re: Version 2.
just out of interest the old land rover foff weighs 5lb 12 ounces ready to run... and is still in use
02-18-2013, 06:19 AM | #72 | |
| Re: Version 2. Quote:
02-18-2013, 08:04 AM | #73 |
| Re: Version 2.
They took about 10 days. I have ordered stuff before and it always seem to be about that time. I just got another chrome set to use. I haven't had any problem with hexes stripping except on 2 wheels i didn't tighten properly. The center hole needs opening up a bit if using axial hexes because of the lip on the hex. The beadlock screws are stainless steel, a nice touch. Just to say i ran it on 4s a couple of days ago and blew a universal on the rear driveshaft which is off an emaxx after 2 minutes. i was using some old ansmann 1/10 truggy wheels on dirt just for a test run. must order some mip's i guess. |
02-18-2013, 09:04 AM | #74 |
| Re: Version 2.
Cool, thanks for the info. |
02-20-2013, 10:48 AM | #75 |
| Re: Version 2.
Well just got back from a beach test and after 5 minutes it blew the rear universal on the driveshaft. Obviously e maxx shafts are not good enough for this beast. I got some junfac shafts a couple of days ago so will have to get them fitted. Power is good, too much power is fun Last edited by M1tch; 02-20-2013 at 10:51 AM. |
02-20-2013, 08:56 PM | #76 |
| Re: Version 2.
Do you have them in yet? Are you going out in the morning to test them out? Let us know, we're all anxiously waiting the results. |
02-21-2013, 02:55 AM | #77 |
| Re: Version 2.
Well I'm away from home at house by a beach. ( its 6 degrees C with 20-30 mph winds. ! "shiver"). The emaxx shaft is fixed, but it won't last long I reckon. The junfac shafts I do have are at home 70 miles away. The long centre shaft needs modifying to fit them anyway as the junfacs have a 5mm hole, while the centre shaft is 6mm with flats that fit the emaxx driveshaft. The power just pops the universal pins out, I have a spare set but that's all. The suspension needs setting up as springs are too hard each end. Also the cheap servo can't keep the steering straight under power. I can only give it half power and then it goes out of control. The good thing is that half power is as fast as the old land rover foff on full power The truck is very stable though, and rarely flips or rolls so that's good. I might give a run today and maybe get some video. After all the time and hassle building this, I'm glad it's running and knew I would have to spend some time on setting it up. |
02-21-2013, 06:32 AM | #78 |
| Re: Version 2.
Brrrrrrr, that's cold. I hope all works out and will be waiting on the video. |
02-21-2013, 11:34 AM | #79 |
| Re: Version 2.
Well now no steering at all. I think the bec in the ESC may be dead. Will have a look at it tomorrow, too pissed of atm. |
02-21-2013, 11:42 AM | #80 |
| Re: Version 2.
I hear ya, I was that way yesterday. A good nights sleep revived me. I woke up this morning and it all came together. Hope you get it fixed soon. |
Version 2. - Similar Threads | ||||
J2-tt version 2.0 | 4stAir | Tamiya Clod Buster | 16 | 06-14-2007 10:24 PM |
My Version of the FJ | ICruzr | 1.9 Scale Rigs | 4 | 05-22-2007 10:28 AM |
Which Version | All Out Racing | Chit Chat | 11 | 10-01-2006 08:48 PM |
version 1, R.I.P. | superelmer | Tamiya TLT Crawlers | 4 | 06-06-2006 02:09 PM |
which version of the 1:6 is better | xmaxxboyx | General Crawlers | 5 | 01-10-2006 02:47 PM |
