02-21-2013, 01:38 PM | #81 |
RCC Addict Join Date: Nov 2010 Location: England
| Re: Version 2.
Thanks. Sometimes frustration gets the better of me. If I was at home I would be on it straight away, but limited parts here just means play with something else. In the mood now to check everything over.
02-21-2013, 01:41 PM | #82 |
Rock Crawler Join Date: Oct 2011 Location: south of nowhere
| Re: Version 2. That blows man, and when its that fawken cold everything pisses you off.
02-21-2013, 01:45 PM | #83 |
| Re: Version 2.
Well I had my little stampede to play with, now that's doing "clicky clicketty" on the transmission. Think I'll drive it til it breaks |
02-21-2013, 10:27 PM | #84 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
| Re: Version 2.
Over the years I've learned that if you see or hear something out of place or sorts, then check it out so it doesn't cost alot more $$$.$$ in the long run. Simple routine maintenance will save you, anyone,.money in the long haul. |
02-22-2013, 08:57 AM | #85 |
| Re: Version 2.
Well the stampede fixed itself somehow and the foff decided to work with my nephews controller' so some video of both tomorrow as I head home tonight. The foff wrecked the rear universal again and destroyed it. Junfac shafts at home will be fitted when I can do some work on the output shaft to get the ends down to 5mm. All good fun, and need to fine tune the suspension soon hopefully. |
02-22-2013, 09:10 AM | #86 |
| Re: Version 2. How long did run before shredding the shaft? |
02-22-2013, 10:31 AM | #87 |
| Re: Version 2.
Oh maybe almost 10 minutes. I fixed the shafts by replacing the missing pin with a 3mm bolt and nyloc nut. That went through another pin which the 'ears of the shafts just twisted off. Pics and video sometime. I think maybe running o/d front u/d rear is too much as this truck is so powerful even on sand it's doing harm, so will swap the rear to overdrive sometime. The hard suspension makes its bounce and spin out, so needs sorting. I can't even give a top speed as it can't stay straight. Last edited by M1tch; 02-22-2013 at 01:05 PM. |
02-22-2013, 01:17 PM | #88 |
| Re: Version 2.
Just got home. a quick video of the damaged driveshaft universal Another video coming soon of it before the shaft broke. You will be impressed. or dead |
02-22-2013, 01:57 PM | #89 |
| Re: Version 2.
The other video. Note: at no time was this flat out, it would spin or flip if any attempt was mode to go over half power. |
02-22-2013, 02:08 PM | #90 |
| Re: Version 2. cool video and rig. Nice job, when will you get some hill climbing videos? Did you get the drive shafts worked out yet? |
02-22-2013, 02:17 PM | #91 |
| Re: Version 2.
I'm just back home and busy the weekend. I will sort the suspension out, but am now wondering if the Junfac shafts will be tough enough, but will give them a try. They are only meant for an scx10 so will find out how good they are. Steep stuff will come sometime, but just want to get it sorted and reliable first. |
02-22-2013, 02:30 PM | #92 |
| Re: Version 2.
Gotcha, you might have to get MIP's. I would still try what you have. |
02-22-2013, 02:56 PM | #93 |
| Re: Version 2.
well it seems MIP don't make center drive shafts for e maxx.. there are traxxas ones,# TRA4951R, but can't find them on sale in the UK. just will have to try the junfac's and see what breaks next lol.
02-22-2013, 08:48 PM | #94 |
| Re: Version 2. I drilled my MIP out to fit on a Summit transmission output shaft. It look real good, the only this is you'll have to run 2 set screws thru it to clamp on the shaft. I'll post pic's and drill bit size if you want. LMK. |
03-21-2013, 11:32 AM | #95 |
| Re: Version 2.
Well, eventually I had time to do a little more. Made up a center drive using the emaxx shaft with a bit of machining and also spur mount. The machining is not too good as i can only use an old lathe at work for the moment. The Junfac shafts fit fine and the pins that come with the Axial gears fit straight in. Now of course it starts raining again ffs |
03-21-2013, 04:22 PM | #96 |
| Re: Version 2.
There ya go, nice job.
03-22-2013, 06:54 PM | #97 |
| Re: Version 2.
Looks good, hope it heals your wounds |
04-01-2013, 09:22 PM | #98 |
| Re: Version 2.
LOL. look at the start date of this thread... almost a year More to come soon, but I have been busy working on a local race track and had very little time. The steering servo was too weak, and I also don't think the servo saver was any good and causing the spins, so there is a Savok 1256TG with alloy arm on now and hope to run it soon. |
04-01-2013, 10:20 PM | #99 |
| Re: Version 2.
Sweet, hope to see some video real soon. |
04-04-2013, 05:19 AM | #100 |
| Re: Version 2.
Well went off to the local river bank to play around and check out the new shaft I made. After 5 minutes and 1 battery it stripped a rear wheel hex. I guess aluminium wheels are needed This thing is stupid powerful on 4s. I have a couple of 3s I might try. |
Version 2. - Similar Threads | ||||
J2-tt version 2.0 | 4stAir | Tamiya Clod Buster | 16 | 06-14-2007 10:24 PM |
My Version of the FJ | ICruzr | 1.9 Scale Rigs | 4 | 05-22-2007 10:28 AM |
Which Version | All Out Racing | Chit Chat | 11 | 10-01-2006 08:48 PM |
version 1, R.I.P. | superelmer | Tamiya TLT Crawlers | 4 | 06-06-2006 02:09 PM |
which version of the 1:6 is better | xmaxxboyx | General Crawlers | 5 | 01-10-2006 02:47 PM |
