Go Back   RCCrawler Forums > Miscellaneous > Formula Offroad
Thread: Foff wheel advice
Old 12-09-2013, 10:27 PM   #1
Default Foff wheel advice
I had a foff that i ran a few times, parted it out and am now building a new one. Anyways Im pondering wheels for the new rig. I had proline beadlocks on the last one and lost a bead after a few packs. I also didnt trust the plastic hex's at all. Im a big fan of slw compatible wheels but most slw compatible wheels are 1" wide or less. Id like at least 1.5" wide wheels that are also lightweight. Anyone have any suggestions? I was thinking of old stampede wheels with slw hubs mounted to them. Stupid idea?
dittohead is offline   Reply With Quote
Old 12-10-2013, 08:34 AM   #2
Default Re: Foff wheel advice
I had Crawling Calvin make a custom set of Foff wheels for my rig. Strength of them is unmatched. here is a link to my build
DRV KRAWLER FOFF'en Formula Offroad
Cost is very reasonable and durability is bullet proof.
DRV KRAWLER is offline   Reply With Quote
Old 12-10-2013, 09:51 AM   #3
Thanks, those wheels are pretty much what im after.
Old 12-11-2013, 08:49 PM   #4
RPM makes some "wide" offset crawler wheels that I believe are 1.5 inches wide. I believe they come as either the Revolver or Clawz style.
And they are cheap.
meatmonkey is offline   Reply With Quote
Old 12-12-2013, 08:58 AM   #5
I'll second that, Calvin made a set for me and they are the Dog's Do Dahs !!
The BFG is offline   Reply With Quote
Old 12-12-2013, 09:21 AM   #6
Scale Detail Engineering
I've been running cheap GMade MudRock plastic beadlocks: 2.2 Mudrock Beadlock wheels (Black) : Gmade Dealer Webstore
I was building my foff on the cheap with mostly spare parts but wanted a lightweight wheel... I did not expect them to last more than a few runs but they have been on there since I built it.
I really like how wide they are.
I first mounted the Sand Paws on regular crawler wheels and they were too narrow, made the tires balloon up.
I did crack one hex running into a unseen sewer grate at full throttle.
But they are so cheap, I just picked up an extra set.
I also added the hop up beadlock rings which I believe helps strengthen them... I've never lost a bead (ProLine Sand Paws).
johnnyh66 is offline   Reply With Quote
Old 12-16-2013, 03:59 AM   #7
Dune Sport Formula Offroad 2.2 Beadlock Wheels
Katan is offline   Reply With Quote
Old 12-16-2013, 09:59 AM   #8
I had a set of those years ago. Good wheels for sure, i never had an issue with them. Too bad i sold them awhile ago
Old 12-16-2013, 10:03 AM   #9
Originally Posted by Katan View Post
WOW ive never seen/heard of those wheels before! I like them alot!
I did end up picking up a set from Crawlin Calvin. Price was more then right and with slw hubs i can fine tune the width. Awesome vendor to work with as well
Foff wheel advice - Similar Threads
wheel / tire advice cmlooner33 Axial XR10 6 08-26-2013 11:21 AM
Tire/wheel advice for basher optikalillushun Tires and Wheels 3 12-01-2012 08:36 AM
Need advice on wheel and tire choice!!! Chaotic Crawlers Superclass Crawlers 7 09-22-2011 11:40 AM
Need advice on wheel wideners and shocks. ToTheMAXXcrawler Tamiya TLT Crawlers 19 02-03-2010 01:25 PM
Losi 2.2 Comp Wheel advice 75fan Tires and Wheels 10 12-02-2009 02:48 PM
