Go Back   RCCrawler Forums > Miscellaneous > Formula Offroad
Thread: New driver, help needed (Turnigy Trooper SCT)
Old 12-10-2014, 12:38 AM   #21
Default Re: New driver, help needed (Turnigy Trooper SCT)
Originally Posted by zedooo View Post
So guys, do you think 2.2 tires are better for my setup then 2.8?
ATM the setup is cold at 2S, warm at 3S, I think I could go for a bigger pinion/wheel diameter...what do you think?
I'm still saying 2.8s. While there will probably be trimming required you'll find that it'll handle better as well as look better. Us it'll also increase the gear ratio, or at least keep it the same as the 2.2 paddle tires have an OD of something more like a big 1.55. You'll find that the 2.8 sand paw will have and OD of a big SCT truck tire. Just look up '2.8 Wraith' and you'll see how big they really are.
TrilloThrillo110 is offline   Reply With Quote
New driver, help needed (Turnigy Trooper SCT) - Similar Threads
trooper dougjonesdy Chit Chat 0 01-04-2007 09:07 PM
