11-18-2014, 09:56 AM | #21 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
| Re: Foff Build From Texas |
12-04-2014, 10:49 PM | #22 |
Newbie Join Date: Dec 2013 Location: Huntington
Messing around in the yard. Don't even have a body yet and there's carnage! |
12-07-2014, 08:12 AM | #23 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
Wow, good start. If I may make a few suggestions? Ok, thanks. Shocks have WAY to much articulation, maybe thicker oil or more preload. Not too sure how much steering you have, but looks a bit on the low side. You should have about 45° . Here's the important one. Replace the metal spur with delrin. It's easier to replace then the pinion. Also make sure you get the same pitch/mod on both pinion and spur, also have a few of each on hand if you've found your desired speed/ temp range. Happy FOFFin' Last edited by stelerzman; 12-07-2014 at 08:14 AM. |
12-07-2014, 08:16 AM | #24 |
Wow, good start. If I may make a few suggestions? Ok, thanks. Shocks have WAY to much articulation, maybe thicker oil or more preload. Not too sure how much steering you have, but looks a bit on the low side. You should have about 45° . Here's the important one. Replace the metal supr with delrin. It's easier to replace then the spur. Also make sure you get the same pitch/mod on both pinion and spur, also have a few of each on hand if you've found your desired speed/ temp range. Lastly, keep an eye on the gear mesh when you change batteries. Happy FOFFin' |
12-11-2014, 02:50 PM | #25 | |
Newbie Join Date: Dec 2014 Location: England
| Re: Foff Build From Texas Quote: | |
12-11-2014, 02:58 PM | #26 | |
| Re: Foff Build From Texas It is .125" aluminum. Quote:
Thanks for the tips. I'm prob going to put these shocks on my wraith and get some shorter ones for this one. As for the pinion spur, I like having metal on both. I think I just had a low quality pinion. I put on a better pinion and it is holding up. Oh and got a body on it. | |
12-12-2014, 04:28 PM | #27 |
Newbie Join Date: Apr 2012 Location: QC
Nice custom build. Looks great in the pics and Im sure will look awesome in video especially with the new beetle body. How would you compare her to your Wraith?
12-13-2014, 09:44 PM | #28 |
It's a completely different animal. I've got the wraith geared really low for crawling. They're both a lot of fun but they are built for completely different types of terrain. The bug is more fun just to play around in the yard with though being so much faster.
12-21-2014, 10:08 AM | #29 |
what gearing do you have?
12-21-2014, 11:16 AM | #30 |
Right now it's 9/56 32p.
12-25-2014, 07:22 PM | #31 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
that is one awesome rig!!!! as for your pinion getting mauled it looks like it was probably a robinson racing pinion right? i have a hot racing metal spur on my wraith and it ate through RR pinions almost weekly on a 3100kv motor on 2s. i switched to hot racing pinions and they have almost no noticeable wear on them. obviously your setup is head and shoulders above mine but you might get atleast more than one trip around the yard with the hot racing pinion. |
12-25-2014, 08:23 PM | #32 |
Thanks for that info. I'll have to try the HR pinions. I think that one was a traxxas one. I just ordered a Robinson extra hard pinion that they suggest with their steel spur that I have. I've been having issues with the plastic wheels stripping also. So I've got some proline 2.8's for the 17mm hex, got the adapters already. Also got some shorter shocks on the way to get this thing a little lower. |
01-02-2015, 10:17 PM | #33 |
Well I got the shorter shocks installed and the 17mm hexed 2.8" wheels installed. It's a lot lower and wider now. |
01-02-2015, 11:15 PM | #34 |
| Re: Foff Build From Texas Quote: Then I use the thick cardboard (really it's just cardboard from a box lol!) to use as a guide to cut aluminum if I'm making a panel or skid. Heck links I do the same the lol. We don't need no stinking auto cad! Warren Guidry designed the first ATV tire in history on a paper napkin for Interco....the best home grown ideas come from the south! |
01-02-2015, 11:52 PM | #35 |
01-07-2015, 06:43 PM | #36 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
cummins swappin and sas'in a chevrolet?
01-07-2015, 07:11 PM | #37 |
Yep. What gave it away?
01-07-2015, 07:19 PM | #38 |
The ifs frame and making room for the ac compressor. And maybe the engine crossmember with the slotted holes. Not too sure on that one. Maybe first gen? Either way, that's my kind of project. Badass.
01-07-2015, 07:22 PM | #39 |
You hit the nail on the head, 99 Tahoe with 1st gen cummins drivetrain. Only I never got around to hooking up the ac.
01-07-2015, 08:05 PM | #40 |
bitchin, now back to your regularly scheduled programming.
Foff Build From Texas - Similar Threads | ||||
where the Foff am I gonna foff build | ctrwannabe | Formula Offroad | 8 | 11-30-2012 07:37 PM |
My new FOFF build | West Cork Basher | Formula Offroad | 124 | 08-27-2012 04:32 AM |
First FOFF build | banditrc | Formula Offroad | 10 | 05-02-2012 09:12 PM |
I want to build a FOFF ( Ax-10 ) | West Cork Basher | Formula Offroad | 4 | 10-14-2011 03:09 PM |
Going to build foff need help | Motomeyhem | Formula Offroad | 2 | 08-03-2011 12:39 AM |
