Go Back   RCCrawler Forums > Miscellaneous > Formula Offroad
Thread: Wraith axles on BWD Whiplash?
Old 11-09-2014, 10:10 AM   #1
Default Wraith axles on BWD Whiplash?
Can anyone confirm if the Wraith axles would work with the BWD Whiplash chassis?
I have some concerns since the Wraith axles have offset pumpkins and the drive shaft angle would interfere with the links or the center section of the chassis itself.
I do have Supershafty extended outputs which I think should solve the problem.
Would hate to buy the chassis and finding out it wouldn't fit.
Pictures would be great.
Help a bro out. Thanks.
Mudsy is offline   Reply With Quote
Old 11-10-2014, 10:38 AM   #2
Default Re: Wraith axles on BWD Whiplash?
The offset pumpkins of the AR60's make them not work on the Whiplash as far as bolt on easy goes. That said, I do happen to be working on the Whiplash 2.0 which will work with them, and is in fact designed around the AR60 axle. It's a substantially different animal.
BW
billet works is offline   Reply With Quote
Old 11-10-2014, 04:42 PM   #3
I had to check out the store just cause I read this thread....very impressive chassis! I like to have one w/CMS, is that even an option/possible.
Damn fine reason for me to look for a set of axles that has zero offset. Every time I log onto this site I find someway to spend money.
Alexander_0_1 is offline   Reply With Quote
Old 11-10-2014, 06:26 PM   #4
BW
Time frame on 2.0 whiplash chassis be be release on your website?
I am really looking forward to it.
Old 11-10-2014, 07:36 PM   #5
Def possible and a planned option
I hope to reveal it in the near future...hoping prior to turkey day.
Old 12-03-2014, 12:57 PM   #6
Any update on this chassis yet?
Old 12-20-2014, 03:09 PM   #7
I have some AR60 axles needing a new home, Any update on the 2.0 whiplash?
Rc Pro is offline   Reply With Quote
Old 12-21-2014, 12:51 AM   #8
Location: Turn the mayflower around.. it will never work
Almost Santa day........... Revealed yet?
JokersWild is offline   Reply With Quote
Old 01-27-2015, 03:27 PM   #9
Ever get anything figured out on this?
texas4x4hoe is offline   Reply With Quote
Wraith axles on BWD Whiplash? - Similar Threads
Rockerīs BWD Whiplash rekcor Formula Offroad 30 01-14-2012 04:49 PM
bwd whiplash 12.5 0r 13.5? Skier Formula Offroad 5 09-20-2011 06:45 PM
