Go Back   RCCrawler Forums > Miscellaneous > Formula Offroad
Thread: 2.2 vs 2.8 Sandpaw on 3400kv motor
Old 01-25-2015, 01:25 AM   #1
Default 2.2 vs 2.8 Sandpaw on 3400kv motor
I plan to run 3s 3400 to 3800 kv 4 poles motor on wraith drive line, would i be better using 2.2 or 2.8 sand paw tyre?
i like the 2.2 because i can use vp hub on ci 6 bolts wheel for different offset and metal hex, but worry that with the smaller 2.2, i won't have enough speed on very soft sand....
what do you guys think?
Colgout is offline   Reply With Quote
Old 01-25-2015, 11:39 AM   #2
Default Re: 2.2 vs 2.8 Sandpaw on 3400kv motor
2.8 Sand Paw, definitely!
2.2 paws are too small. Car is always stuck somewhere
Hadesbear is offline   Reply With Quote
Old 01-25-2015, 01:07 PM   #3
I'm running the 2.8's because to me the 2.2's look too small like Hadesbear said. I was using 12mm hex proline wheels and kept stripping out the wheels. Then I found the Proline 2755-03 2.8" wheel with a 17mm hex and mounted them up with some adapters. Also the wheels are beefier around the hex area. Haven't stripped one yet on MMP and 5700kv.
Adapters I used the widest ones, they have some different widths.
17mm Front Wheel Adapters: Pro-Line Racing | Most-winning RC parts and accessories! | RC Parts, Traxxas Parts, RC Crawler, RC Wheels, RC Tires, RC Bodies
Wheels
Pro-Line 2755-03 F-11 2.8" Black Wheels
texas4x4hoe is offline   Reply With Quote
Old 01-26-2015, 10:49 PM   #4
What are the good 17mm hex adaptor around, I like the MIP one and Aka one because they are made with 7075 alloy, most other are 6061.
Old 01-27-2015, 03:19 PM   #5
Not really sure about any of the others but I haven't had any problems from the proline's I have.
Old 01-27-2015, 08:08 PM   #6
your proline is good, it is 7075. But they are sold in pair and a bit expensive to get a set of 4. I have order a set of MIP and also a set of teckno. Interesting to see if the teckno will last as they are plastic....
Old 01-27-2015, 08:16 PM   #7
The proline wheels with the 17mm hex I'm using are plastic and they seem to be holding up.
2.2 vs 2.8 Sandpaw on 3400kv motor - Similar Threads
Hs worm gears 3400kv 2s lipo Gvm23 Kyosho Crawlers 1 04-08-2014 12:01 PM
Hobbywing xerun 3656 3400kv Gvm23 Electronics 26 01-30-2014 01:23 PM
