Go Back   RCCrawler Forums > Miscellaneous > Formula Offroad
Thread: dp built "ROWDY BRONCO" FOFF rig
Old 08-20-2015, 05:46 PM   #1
distinctive pd's Avatar
Default dp built "ROWDY BRONCO" FOFF rig
Been quit awhile since I built an FOFF rig. It's time for another.
The ROWDY BRONCO. ..
Arne Johanessen is by far my favorite FOFF driver to watch and his rig is freakin sweet!
Wont be exact replica but close too!!
Build parts list:
-Custom tube chassis and alum skid
-Pro-line Wraith BRONCO body
-Dlux big bearing built AR60s (narrowed rear)
-Custom cut and shut paddles done by me
-Bombproof Axial transmission
-BWD FOFF motor plate
-Custom machined DUUUUUUDE 2.2 delrin wheels
-elect...TBD
distinctive pd is offline   Reply With Quote
Old 08-20-2015, 06:18 PM   #2
Default Re: dp built "ROWDY BRONCO" FOFF rig
Start on the lower skid and lower link mounts...
DUUUUUUUUUUUUUUDE wheels!!! Going to look sweet with OMF rings!
Old 08-21-2015, 12:18 AM   #3
You've got my attention...please continue.
89redranger is offline   Reply With Quote
Old 08-30-2015, 10:16 AM   #4
Been super busy with work but ive had time to work on the paddles here and there!!
HERE THEY ARE BEFORE AND AFTER!!
Old 08-30-2015, 12:56 PM   #5
Those tires came out awesome. Should fit the scheme well. If you want to further clean up the sidewalls after shaving, cutting, and gluing get after them with a little sandpaper. I usually use a little 220 by hand and get very smooth sidewalls and glue joints. Another step further would be to buff that out by hand with a scotchbrite pad. I can almost get them to the point that you can't tell they were modified. Almost...
Old 10-01-2015, 08:36 PM   #6
Thanx!!!!!!
Wheels were a custom ordered delrin, machined by DUUUUUUUUUUUUUDE
got some more done on the front end tube work and axles...
STARTING TO LOOK LIKE A BRONC!!!!!!!
dp built "ROWDY BRONCO" FOFF rig - Similar Threads
<iframe width="420" height="315" src="//www.youtube.com/embed/gYr-dbPEOnE" frameborde boolean21 Scale Videos! 0 10-01-2013 09:39 AM
"The City Brawlers Challenge" KOM Foff April 20th! Mr Glassman Colorado 31 05-06-2011 09:21 PM
My Class 3 rig, "Orange Crush Bronco" Oso787 2.2 Scale Rigs 141 04-14-2011 06:24 PM
