Go Back   RCCrawler Forums > Miscellaneous > Formula Offroad
Thread: Formula off-road "Wild Wheely"
Old 09-25-2008, 01:58 PM   #121
I agree ..BL in a WK is too much fun
I have only replaced the diff gears once sins I got it in Dec. 07
The new hardened Diff gears are 36/14 ... that will hopefully be enough to push my WK past 30 Mph with Sand Paw tires and īPede gearbox
SnoopMaxx is offline   Reply With Quote
Old 10-14-2008, 03:51 AM   #122
I have 4 new videoīs
Formula Off-Road with Sand Paw
Formula Off-Road with MudSlingers 2.2
Wild wheely King Trail Ride part 2
Thingīs donīt always go as planeīd
Bloopers īn Crash
c",)
Old 11-21-2008, 01:26 PM   #123
You need some more room. A nice big hill would be cool.
super mud is offline   Reply With Quote
Old 11-21-2008, 02:49 PM   #124
That would be awesome
Old 11-21-2008, 03:58 PM   #125
Originally Posted by 2JSC View Post
I think you should make it looke like this Willy
But I'm really looking forward to this build!
Or, make it look like my willys
its a rock buggy but you get what i meen lol
http://s292.photobucket.com/albums/m...t=IMG_1130.jpg
47willysbuggy is offline   Reply With Quote
Old 11-22-2008, 06:56 AM   #126
Thatīs a great looking rig you got there 47willysbuggy
Old 02-13-2009, 01:19 PM   #127
hey there snoopmaxx! awesome build man!
can you tell me what are the white rims you are using with the sand paws as i got the paws but im looking for some rims for my build and they look very good?
cheers and keep up the good work!
djrobot is offline   Reply With Quote
Old 02-13-2009, 02:04 PM   #128
Hey djrobot
The white rims are from an old Tamiya Stadium Blitzer
Cheers
Old 02-13-2009, 05:20 PM   #129
are they 12mm hex compatible and do you know the actual manufacturer?
cheers mate !
i just started in the off roading, i have a RC4WD timberwolf but want to build a formula off road car. this is my build thread - i just started man!
http://www.rc4wdforum.com/showthread.php?t=4540
i got a set of HPI scorcher 6 spoke wheels , will the panthers or prolines fit these?
Old 02-13-2009, 10:45 PM   #130
snoopmaxx
Nice build. I just finished my WK 5700 mamba 3cell lipo build, I am now thinking chassis options, yours looks like it is much more controlable. also if you blow those gears try esavage gears they are the only reason I pulled out the WK axles again
rocresq is offline   Reply With Quote
Old 02-14-2009, 02:45 PM   #131
cheers mate !
Yes they have a 12mm hex, the manufacturer is TAMIYA and the model where they came from was a Stadium Blitzer
I only drilled a 7mm hole to make them fit on the WK hex
Nice build. I just finished my WK 5700 mamba 3cell lipo build, I am now thinking chassis options, yours looks like it is much more controllable. also if you blow those gears try E-savage gears they are the only reason I pulled out the WK axles again
Thankīs I all ready have hardened Savage diff gears
You can get the chassis I use
Here
http://www.4x4rc.no/ds_product_info....roducts_id=191
Here is my first chassis design
based on the Midgard ProRock
I also have another chassis that I helped in designing
My chassis is no. 2 of only 5 chassis made
Old 02-15-2009, 12:50 PM   #132
Originally Posted by SnoopMaxx View Post
Sweet What set-up do you have ?
The wheels looks to wide for the Sand Paw
I don't know how I let this thread slip my mine, anyway I'm glad I came back across it. In my truck on the prior page, I run a sidewinder 4600 on 3s and it has axial axles. I have since bought and used WK axles on another project truck of mine and do like the extra width of the WK axles. The extra wide wheels just allows a larger contact patch in effort to making it "float" better across sand.
Keep up your progression in this formula off-road stuff and thanks again for the inspiration
S_C_I_P_I_O79 is offline   Reply With Quote
Old 02-15-2009, 03:15 PM   #133
Will do and Your welcome S_C_I_P_I_O79
A little update I now have a 38T/22T mod1 gearing that I will be testing as soon as the
snow melts
But until then itīs E-Maxx bashing time in the snow ..... With paddles
Old 02-16-2009, 10:42 AM   #134
A photo from last summer
And a few from today
I now have a 22T/38T gearing on my Formula Off-Road
And with the VXL
It should be able to reach speeds above 30Mph
Old 02-19-2009, 03:54 PM   #135
Default u-tube buddy
i got the sand paw idea from ur videos on tube heres my king so far video on u-tube soon. 17 turn motor high torque servo li-po battery
chongdigga is offline   Reply With Quote
Old 02-19-2009, 04:04 PM   #136
That looks awesome chongdigga
What motor do you use ? Still the stock one ?
and whatīs your WB ? around 14" ?
I made a mod1 22T pinion the other day
and I had a 38T mod 1 Revo spur as well
so now my Foff should exceed 30Mph With the MudSlingers
EDIT: Is that the MIP drive shafts ?
Old 02-19-2009, 04:47 PM   #137
i got the drive shafts with my integy crawler kit thro x-town rc.
17 turn raven motor
tazer 15t speedcontrol
hi-tec high torque servo
li-po battery
locked diffs.
dont know the wb now had 2 shortin it a lil because of allum. chassis
still a work in progress
Old 02-20-2009, 11:46 AM   #138
Cool I like that chassis in black
Old 02-22-2009, 01:54 PM   #139
hey snoop check out my new pics no video yet but the pics r in motion. my sand king
Old 02-23-2009, 01:51 PM   #140
I asked Thrandura at www.4x4offroads.com for the Foff specs.
and here they are
http://www.4x4offroads.com/formula-o...ification.html
