06-10-2010, 07:33 AM | #81 |
Yep, I had to put a modded Maxx shaft up front. The stock output yoke ears are done on one end.
06-10-2010, 08:27 AM | #82 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
you tryout those creeps yet? thats a very badass heli motor! |
06-10-2010, 08:31 AM | #83 |
I was going to swap them soon. I dont have an extra set of wheels right now. so I gotta bust up the gmade's. I think that stock foam is too stiff. I tried a set of stock rover foams and they seemed alot better. I just got my moonbuggy berg chassis in as well, so I have been working on that the past few nights.
06-12-2010, 10:19 AM | #84 |
| New tires
Got a set of RC4WD's 2.2 Spooky Crawlers from rubiredunlmtd to test out. And some donated beadlock rings from rubiredunlmtd. They aren't as grippy as the Etna cuts but they still work good. I put in some stock rover foams. The Spooky foams seemed way to stiff and bouncy, rover foams are alot better. To scale it up more, i think some smaller diameter shock bodies are in need. I put a modded maxx shaft up front the other day. But the front one started slipping today. The axle output shaft is drilled through for the stock pass through pins. I drilled it out to 3mm and tapped it. Now, it aint coming loose. Two 3mm screws go almost through the output shaft. I flipped this over and hit fwd/rev several times and the motor locked up. Like it's not getting power to all 3 phases again. I have unhooked and rehooked the motor wires up several times. That worked last time, guess it was a bad connection. Not fixing it this time. Any suggestions? Last edited by Szczerba; 06-12-2010 at 11:12 AM. |
06-12-2010, 01:11 PM | #85 |
LOOKS GOOD! THOSE SPOOKYS ARE STILL NEW,SO BREAK'EM IN !! |
06-12-2010, 01:25 PM | #86 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
Tires look nice. |
06-19-2010, 09:12 PM | #87 | |
Newbie Join Date: May 2010 Location: us
I have enjoyed your thread Gary | |
06-21-2010, 10:21 AM | #88 |
Thanks for the tips BLUSABER. It ended up being the 4mm bullet connectors coming from the motor. I guess they had a bad connection or a cold solder, etc. After much troubleshooting, I just cut the bullets off and direct soldered them to the ESC. Fires up like a champ everytime now. I have added some timing via the CC software. Like you said, it doesn't crawl worth a darn, esp on 18t pinion, but it is a high speed heli motor! It works for rock bashing with me. On another note, I glued up the stock tires/foams to some HPI 5-Star plastic wheels. Gives it an even wider stance and doesn't look bad either. I'll post some pictures later. Still waiting on parts from Junfac. 8 days after I bought and paid for some front cvd axle shafts, I finally got a "shipped" notice on them. Still 3WD for now. .... Last edited by Szczerba; 06-21-2010 at 10:27 AM. |
06-23-2010, 02:56 PM | #89 |
Quarry Creeper Join Date: Feb 2008 Location: Pittsburgh PA
how well do the rock crushers perform for ya? Lance |
06-24-2010, 07:58 PM | #90 |
| Quite well, after I removed about 2/3 of the tread! Great for bashing and ok for crawling. I am running a thin 1/2" slice of non memory foam with two 1" wide memory foams on the outside of the non memory. Works ok. The tires are still kinda bouncy, just the compound and sidewall thickness that causes that. But it doesn't crawl too well right now with the outrunner and 18t pinion. Still waiting on a front portal axle shaft from S. Korea! In the meantime, I have sold this truck. Last edited by Szczerba; 08-03-2010 at 11:03 AM. |
06-24-2010, 09:49 PM | #91 | |
Thanks, i ordered a set with my gmade r1, it should all come in the mail next tuesday, i really liked how scaleish it looks with the rock crushers. Could the r1 be considered a scaler? I mean if you put a driver and some scale accesories on it, pop it on a trailer. Would/could it be called a scaler. Trailered rig. Idk but i have great plans for this truck, really just cant wait to get it. Lance | |
02-15-2011, 08:24 PM | #92 |
Rock Stacker Join Date: Dec 2008 Location: CARO
did any of you guys have any coging issues, i have a mamba max with the hkll 2221-12 an im getting alot of coging in the low end i tried turning the start power up an the punch this set up is in a honcho
02-15-2011, 08:31 PM | #93 |
02-15-2011, 08:47 PM | #94 |
ya i know that, this is cogging to wear i cant rilley crawl slow with it ,it wants to cog out then jump
02-15-2011, 09:11 PM | #95 |
02-16-2011, 07:15 PM | #96 |
cool wasnt sure, ill keep it around for trail motor it will work good for that thanks duuuuude |
04-02-2014, 09:49 AM | #97 |
Newbie Join Date: Mar 2014 Location: angeles philippines
| Re: Shane's GMade R1 Rock Buggy Build
Just Ordered the R1 and front battery plate. What is the size and spec of your batteries that you are running? I have a Novak crusher / ballistic 21.5 t to go in but have no idea of what size batts i can fit as yet. your help and a dice would be appreciated. |
04-02-2014, 10:08 AM | #98 |
| Re: Shane's GMade R1 Rock Buggy Build See post #73.
04-02-2014, 02:43 PM | #99 |
Thanks mate, Picked up a lot of good stuff from your thread for my build. I am new to electric power and the stuff you have posted is excellent. Cheers |
