01-10-2012, 11:04 AM | #181 |
Pebble Pounder Join Date: Jun 2011 Location: Yucca Valley, CA
| Re: Szczerba's JK (Minus some doors) |
01-10-2012, 11:30 AM | #182 | ||
| Re: Szczerba's JK (Minus some doors) Quote:
It's 8.5lbs RTR, thats with a 2200mah 3S lipo. It crawls alot better on the slow end now so I am going to put a 90T spur in it gain a little more low end control. | ||
01-10-2012, 12:52 PM | #183 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
damn,shane... you left saturday without getn your headlights from me.. ill have them this weekend,dont let me forget. |
01-10-2012, 11:11 PM | #184 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
Trying to get this other jk built for a customer and keep coming back to when I did this one. Still my favorite build and hope I can recreate some magic Clear Eyes, Full Hearts, Can't Lose |
01-11-2012, 12:25 AM | #185 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
Clay...you can do it! I wish I could deal with you...but time is not on my side. Post up on any work you do...I'd love to see it. You nailed this one, you can do it again. |
02-13-2012, 08:06 PM | #186 | |||
I ordered up some 5x8x2.5 traxxas bushings to see if they will last longer than the small bearings that go in the portal cases. I had one bearing fail and caused a portal bearing to get knarled up. Nothing a dremel couldn't fix on the gear teeth. | |||
02-15-2012, 11:29 PM | #187 | |
Quarry Creeper Join Date: Sep 2011 Location: NW
10-09-2012, 11:12 AM | #188 |
ahhh S^*T Join Date: Mar 2012 Location: in the shop bending metal in Whatcom Co. WA.
this thing is bad |
10-09-2012, 12:58 PM | #189 |
10-11-2012, 12:51 AM | #190 | |
Pebble Pounder Join Date: Jun 2012 Location: Salisbury
| Re: Steering Quote:
10-11-2012, 06:21 AM | #191 | |
| Re: Steering Quote:
Post #15 and Post #48 show the details. Buy the TLT parts from RCP and build them as normal and then cut them down, as pictured. Then slowly grind the shaft flat on one side to fit inside the portal gear. Go slow and don't take too much off. I have links to the thread where Chino did this as well. Although if you do the rear steer, just read that you have to buy front portal gears, as they are different than the rear gears. | |
10-13-2012, 11:06 AM | #192 |
can you tell me what all products i need to get to do that mod. so i can order them. i see the cvc parts but what pins do i need to get.
11-06-2012, 07:11 AM | #193 |
Rock Stacker Join Date: Jan 2012 Location: eldorado
this rig is sweet. its sad you aint got it cause a set of the new 2.2 pitbull rockers would look SICK on that thing. any way extremely nice rig and very detailed pics
11-06-2012, 07:26 AM | #194 | |
Thanks, I probably shouldn't have let this one go but I say that about all my builds. | |
