07-12-2011, 03:30 PM | #1 |
Newbie Join Date: Jun 2011 Location: na
| Novak ballistic clearance issue
I'm currently running with the Novak ballistic brushless 17t motor. Has anyone had issued where the motor sits up right against the side of the roll-cage? I have a 12t pinion and wanted to got up to a 16t or a 18t but with the 12t pinion it is already rubbing the chassis. I did a little bit of dremelling to make it fit with the 12t.
07-12-2011, 08:27 PM | #2 |
RCC Addict Join Date: Jan 2010 Location: Vermont
You can move the skid back for extra clearance. I believe the stock ones have the extra holes for it.
07-12-2011, 10:51 PM | #3 | |
Newbie Join Date: Nov 2010 Location: Canada
| Quote:
True, while the skid plate holes are there I found myself only being able to fit the transmission in its stock position. I'm pretty damn sure I tried all available different combinations of mounting holes being used and remember asking myself why the HELL they even bothered having the other holes drilled. OP, I am using a 21 turn hobbywing sensored brushless motor and i had to shave off some of the tube frame to make it fit. I even had to cut off a portion of the small electronics tray, the small one in the front, so that the wire tabs would fit in the position I wanted them in and that was upwards. Structural integrity was not compromised as far as I can tell and my rig has survived some pretty vehement tumbles down the same steep hill since then without any signs of further breakage. Last edited by waffelhauz; 07-13-2011 at 10:43 AM. | |
07-13-2011, 07:25 AM | #4 | |
| Quote:
Good luck! | |
07-13-2011, 12:46 PM | #5 |
Thanks for the reply's. I'll just keep with the stock pinion. Don't want to shave to much off.
07-16-2011, 10:18 AM | #6 |
Quarry Creeper Join Date: Apr 2010 Location: virginia beach
I have an axial tranns in mine and I have all the room I will ever need and didn't have to shave anything
07-16-2011, 09:01 PM | #7 |
Newbie Join Date: Jun 2011 Location: Australia
I had sort of the same problem but with the Goat 18.5t motor it would sit up against the upper link mount rod end thing all i did was got a different rod end but in your case if its sits up against the cage you could maybe cut a little section out or just shave some off like you said. Cheers Matt |
07-17-2011, 03:18 PM | #8 |
Pebble Pounder Join Date: Mar 2011 Location: Wales,UK
I originally fitted a Hobbyking 3980kV motor with a long motor can and that rubbed on the chassis cage. Swapped it to a Hobbyking 3500kV outrunner 450 heli motor and problem well n truely gone, new motor is a quarter the size of the old !
03-20-2012, 09:17 PM | #9 |
Newbie Join Date: Mar 2012 Location: Big Sky Country
| Re: Novak ballistic clearance issue
I had this same issue with an axial 27T. I got around that by spacing the entire frame with washers. Clears fine now.
