Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: gmade r1
Old 11-13-2011, 11:03 PM   #1
Default gmade r1
i know someone did something like i want to do running gmade axles on a scx10 chassis what do i need to make the axles work with the frame and can i use the gmade tranny or do i have to use the axial i have a 55 turn terra claw motor and a dynamite tazer speed control so im not going fast i just want to crawl thanks everybody
exmark is offline   Reply With Quote
Old 11-14-2011, 01:18 AM   #2
Pop this question into the scx10 section too probably more chance of an answer.
northernerbill is offline   Reply With Quote
Old 12-04-2011, 09:13 PM   #3
Default gmade
I look at what you are doing tday i am new to rcc and i see it was nov when you post this but if you didnt use the gmade parts let me know i will make you a offer on them
tire king is offline   Reply With Quote
Old 12-05-2011, 10:43 PM   #4
let me know if you are going to sell your gmade r1 chassis im looking for one
1976drew is offline   Reply With Quote
Old 12-12-2011, 07:15 PM   #5
I did this with mine. I used honcho links for the lowers and car tie rods for the uppers. Now that I have the lengths, I'll make my own links
I used the axial tranny just because it bolted right in. Finding drive shafts was a complete pain though.
bbaxter51 is offline   Reply With Quote
Old 12-13-2011, 12:22 AM   #6
Sweet I'm about to blend the same for a jeep project.
What issues did you have with drive shafts then?
Old 12-13-2011, 11:25 AM   #7
My issues came with the rear drive shaft length. When I ordered Junfac shafts for a honcho, the rear was too short by about 10mm. I ended using the rear honcho Junfac shaft for the front and had to buy a punisher shaft for the rear. It's obscenely big, but it was the only shaft I could find that fit for the rear. At least I dont have to worry about breaking it.
Here's a comparison from the rear to the front shaft.
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
