Gmade driveshafts I just bought the hd steel replacement driveshafts for my r1, The question is the set screws that come with the driveshafts, I would rather use the stock set screw pins that came with the plastic stock shafts,but of coarse the threads are different sizes,just thinking the steel shafts might slip if Iam hard on the throttle,anybody have any thoughts on useing these steel gmade shafts? or has any one used the screw pins instead of the set screws, if so what kind? |
Re: Gmade driveshafts I have used the stock set screws in all of my junfac steel drive shafts without any issues with the threads . I have also used the axial set screw part #AXA175 in the junfac steel drive shafts. You can get them here if you LHS does not have any. Axial Wraith Screw Shaft M3x2.5x11mm (10pcs |
Re: Gmade driveshafts Thankyou, Ill be stopping by my lhs on the way home,just dont care for the junfac set screws that came with the steel shafts. |
