12-24-2011, 08:34 AM | #1 |
WOOPOOW!! Join Date: Nov 2008 Location: Atlanta, GA
| Colby's Wraith killer Tj
This things been passed around a good bit before finally being finished up by MG200 and sent to me. It's definitely a sweet chassis. Specs
Got a few slow arse packages on the way from RC4wd..... So more updates as soon as things arrive and get put on. Last edited by Colby; 12-24-2011 at 08:36 AM. |
12-24-2011, 09:51 AM | #2 |
| Re: Colby's Wraith killer Tj
Wow Colby that thing is badass looking! If you have questions about axles let me know. |
12-24-2011, 10:12 AM | #3 |
Thanks Eric! and I sure will. Ive already broken a portal axle dog bone and split a drive cup in 2. I saw where I could run TLT cvd's that were modified out the ass. May get fish to help me with a set of those |
12-25-2011, 06:21 PM | #4 | |
| Re: Colby's Wraith killer Tj Quote:
If you want Colby, I will make you deal on MIP's if you want ? | |
12-25-2011, 07:22 PM | #5 |
Very cool rig. I have had zero issues so far with the g-made axles. Hope your luck changes! yep, it's about $42 per axle to do the tlt cvd's from RCP. Parts, how to, pictures in my JK build in the G-Made section. |
12-25-2011, 09:33 PM | #6 | ||
Well, today I was out bashing the wheels off of my rig (seriously) when I did a pretty sweet back flip mctwist-thing and my left rear wheel went flying off, still attached to the axle shaft pulled it apart and noticed all the portal axle bearings were toasted. Luckily I had some stock XR10 bearings... like that's going to last. So we will see what I can come up with. Thanks for all the info Szczerba! | ||
12-25-2011, 09:35 PM | #7 |
Should be at ECC this year. I remember ya. Oh yea, forgot to mention. The axles do blow throw the small portal shaft bearings. |
12-25-2011, 09:43 PM | #8 |
Sweet! I will definetly be there, not promising this will be what I'm running but would love to run with the jk! And yes, it was pretty spectacular. Hopefully will be switching to rear steer in the next few days so that won't be much of a problem anyway |
12-26-2011, 12:03 PM | #9 | |
I order my from Avid bearings. 5x8x2.5 16 total 5x11x4 14 total | |
12-26-2011, 12:15 PM | #10 |
Thanks for the reccomendaton Eric. Will be looking into that. I need to figure this rig out. I am having a KOH/g6 competition at my house January 7th, and it doesn't have much flex due to my desire to keep it as low as possible. What are your thoughts on running a semi droop suspension? Or maybe even a full droop?
12-26-2011, 12:21 PM | #11 | |
My JK is full droop with some small mechanical pencil springs inside SCX shocks with some med-heavy shock oil. It's a bouncy ride but keeps it low. You can play with thicker shock oils to slow down the droop somewhat. The G-Made link mounts are not setup for a rail frame chassis. They are too high. | |
12-26-2011, 12:34 PM | #12 |
Well, my chassis is full tube but it resembles a frame rail chassis. The rear isn't the problem, it flexes fine, but you can see what I'm dealing with up front. I thought of 4 linking it but there still isn't any room to mount the servo... |
12-29-2011, 06:31 PM | #13 |
On my mounts I cut them down them. Have you tried scx shocks ? |
12-30-2011, 01:09 AM | #14 |
Hmm... I like the way you cut the mounts Eric. and Id love to go to SCX shocks but I don't have the cash. They would definetly be easier to tune for my rig. Here's an update of the jeep with the new meats I waited 2 weeks for. Thanks rc4wd.... |
12-30-2011, 03:13 AM | #15 |
RCC Addict Join Date: Nov 2007 Location: -
Wicked man! |
01-02-2012, 09:14 PM | #16 |
Thanks man! Crapped the same bearings out of the rear axle again. I really don't like them thought of switching to Wraith axles, or axials. I love the portals though.
01-02-2012, 10:13 PM | #17 |
Try getting new bearings before giving up on the R1 axles.
01-05-2012, 08:21 AM | #18 |
Newbie Join Date: Sep 2011 Location: Winchester
awesome build is that a shaved 14 bolt in the rear? chromo shafts?
01-09-2012, 03:50 PM | #19 |
Thanks! We had a g6 this past weekend and the jeep ran awesome. I need some new wheels, and i have to fix my rear link. But she handled great. I just was so caught up in running my own event i struggled a bit. Heres some aftermath pics: Also a Huge thanks to eric for the free scx shocks. I will be installing them as soon as i get some time. |
01-09-2012, 04:55 PM | #20 |
Why do you need new wheels ? Stripped the hexes ? Glad you got them, hopefully they will help. |
Colby's Wraith killer Tj - Similar Threads | ||||
Snow Bashing with the Wraith Killer | madscrambler | Scale Videos! | 2 | 11-24-2011 04:09 PM |
The new buggy "Wraith Killer" testing. | madscrambler | Scale Videos! | 6 | 11-10-2011 07:57 AM |
Jason's Wraith, the baby killer. | jason | Axial Wraith | 95 | 07-04-2011 12:11 AM |
Colby's 1.9 Tuber | Colby | 1.9 Scale Rigs | 16 | 06-17-2009 04:07 PM |
