Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: GMade Portal Gear Shafts
Old 01-03-2013, 05:07 PM   #1
Pulled an old #6 on 'em.
offroadace's Avatar
Unhappy GMade Portal Gear Shafts
Does anyone make something stronger? I've snapped the pins out of 3 of them and this last break included the wheel axle.
Thanks
ORA
offroadace is offline   Reply With Quote
Old 01-03-2013, 10:22 PM   #2
Default Re: GMade Portal Gear Shafts
I know the stock axles suck!!!! I have two sets of them and ended up pulling them out and replaced the whole axles with ax10 axles! I broke something in them every time I drove it. I keep going back and forth on whether or not I want to sink anymore money in them. As far as I know there is not any off the shelf bolt in upgraded axle shafts for them. People buy wheely king knuckles and cvd's and modify them to work with the r1 axles.
jeepyj2000 is offline   Reply With Quote
Old 01-04-2013, 06:56 AM   #3
G-FORCE's Avatar
What motor/battery combo are you both running?
G-FORCE is online now   Reply With Quote
Old 01-04-2013, 10:00 AM   #4
offroadace's Avatar
Novak Goat 3S Crawler Brushless System 21.5 + BEC using both 7.4 (2s) and 11.1 (3s). Snapped using both.
I ride the dunes (quads) and take it with me and run around camp. It's not quite hard-packed and has a lot of loose sand and I crawl over the fire wood pile. I don't bash it and I don't run it fast, like my wraith.
Old 01-04-2013, 10:15 AM   #5
Internet Knows You!
Szczerba's Avatar
You can always upgrade to a TLT steering setup.
Alot more strength and more steering. I assume all the parts can still be bought at RCP*Crawlers
They held up to my JK that was 8.5lbs. Just had trouble keeping the small bearings together in the portal gear setup. I never did buy fancy high quality bearings though.
Front Steer
Szczerba's JK (Minus some doors)
Rear Steer
Szczerba is online now   Reply With Quote
Old 01-04-2013, 12:11 PM   #6
offroadace's Avatar
OK, that is an awesome mod.
I am going to look into that one for sure.
Thanks!!!
Old 01-04-2013, 03:11 PM   #7
offroadace's Avatar
OK, so going through your thread and trying to get a list of things I will need. I have 4WS so everything would need to be doubled.
Here is what I am thinking a full parts list would be.
1. 2X - RCP Crawlers Super-Max Clearance TLT Aluminum Knuckle (2)
2. 4X - RCP X MIP CVD Part - Outer Axle
3. 4X - RCP X MIP CVD Part - Short Bone Axle
4. ? - RCP X MIP CVD Part - Cross Pin (handful of these - I need extras anyway)
5. ? - RCP X MIP CVD Part - Set Screw (handful of these - I need extras anyway)
6. 8X - RCP X MIP CVD Part - 6x11x4mm Bearing
7. 4X - RCP X MIP CVD Part - Stock Hex Hub ---- [Or should I go for the 1/4 long hex?]
8. 4X - RCP X MIP CVD Part - Coupling
Old 01-04-2013, 04:59 PM   #8
Power of the Portals
eric113's Avatar
Another way of it doing. Buy 2 sets of theses. Cut them down to length and grind a flat spot.
*RCP*Crawlers*Wheely*King...
eric113 is online now   Reply With Quote
Old 01-04-2013, 05:05 PM   #9
offroadace's Avatar
OH NICE!! I didn't even see those!! Thanks!
Old 01-04-2013, 05:46 PM   #10
Internet Knows You!
Szczerba's Avatar
Yep, Eric is right too.
I think I listed it in my build but it is like $62 an axle to upgrade to TLT stuff, per axle.
Just go slow on grinding the flat spot to fit in the portal gears. Don't wanna take too much off the shaft.
Old 01-04-2013, 06:50 PM   #11
G-FORCE's Avatar
Ok so the Wheely king shafts cut to size works in the Gmade portals? Correct? Do you need to change the hub and carriers?
Old 01-04-2013, 07:28 PM   #12
The shafts fit fine once you grind the flat spot and the Wheely King knuckles fit the GMade c-hubs.
derb is offline   Reply With Quote
Old 01-04-2013, 07:53 PM   #13
G-FORCE's Avatar
Ok so I need the knuckles as well then. Gotcha.
Thanks a million.
Old 01-05-2013, 03:11 PM   #14
offroadace's Avatar
It looks like if you go with the full TLT you need the c-hubs, but if you go with the XVD's you can use the same GMade c-hubs, and it is about $50-60 less.
Old 01-05-2013, 06:20 PM   #15
Pardon me,but what make are the xvd
chbronco is offline   Reply With Quote
Old 01-05-2013, 07:29 PM   #16
eric113's Avatar
Rc4wd
Old 01-05-2013, 09:55 PM   #17
I have on hand(but not at home at work)yota tf2 axles just cut and grind a flat spot no other mods?
GMade Portal Gear Shafts - Similar Threads
GMade portal axle leaf sprung truck? johnnyh66 General Crawlers 3 07-03-2012 08:51 AM
Gmade R1 Rock Buggy Portal Axle any good mudd_slinger General Crawlers 3 12-20-2011 08:25 PM
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
