07-09-2013, 09:51 PM | #1 |
Quarry Creeper Join Date: Jun 2012 Location: Port Coquitlam, BC
| Portal haters
What's up with all the portal axle haters out there. They say they are weak and prone to breaking... I have 12-15 hours on mine and I have only broken ONE wheel axle... and that was due to a 2 meter drop and landing on one wheel... I've been running a ROC412 2300KV motor, weighted wheels, 10/58 gearing and it has help up to the torque without any problems. 8 lbs rig. How well has your portals held up? |
07-09-2013, 10:33 PM | #2 |
Rock Crawler Join Date: Jul 2011 Location: palm desert (southern cali)
Mine were on 10t puller 4 s no probs Sent from my Galaxy Nexus using Tapatalk 2 |
07-09-2013, 10:48 PM | #3 |
Newbie Join Date: May 2013 Location: alpine
| Re: Portal haters
i broke my gmade's within 5mins if not less. my fault though the other 3 corners are doing good so far.
07-10-2013, 05:30 AM | #4 |
Rock Crawler Join Date: Jan 2013 Location: Australia
| Re: Portal haters |
07-10-2013, 09:51 AM | #5 |
Rock Crawler Join Date: Oct 2012 Location: Garden Grove
| Re: Portal haters
They are weak and they are prone to breaking and the smaller bearings suck a$$. I like mine though with the upgrades I did to the knuckles and added XVD's. |
07-10-2013, 11:10 AM | #6 |
| Re: Portal haters
Offroadace, What is weak and prone to breaking? What were you constantly breaking? I consider bearings consumables/maintenance items so they don't really count towards "weak" or "breaking". I want to see if there is indeed a problem with these axle through real experience and not "I heard from a friend's friend that they were junk". I really like them and would like to try and boast there usage in hopes to get some aftermarket coverage. |
07-10-2013, 11:25 AM | #7 |
| Re: Portal haters
Axle pins, dog-bones and small bearings. Yes. Bearings are a maintenance issue, but if you don't catch it in time they are destructive to the gears in the portals. Those small ones suck a$$ and don't last very long. Replaced at least 6 axle pins. Broke 3 dog-bones before I decided to take the time to design an upgrade to a modified aluminum knuckle with a cut set of XVD's. See below. Replaced all bearings and any chattered gears caused by bearing disintegration (completely rebuilt both axles because of this). So it you don't catch the bearings, which fail randomly and are not apparent when they do fail, the bearing bits wrap around the gears and cause a lot of teeth chatter and breakage. Haven't been able to run it much since the upgrades but haven't seen any issues since my mods were applied. I still see those small bearings as a major failure point regardless if it is a general maintenance operation. If you don't check constantly you are in for a world of trouble and time to rebuild. But again, I love the portal axles. Knuckle mod XVD mod |
07-10-2013, 12:59 PM | #8 |
| Re: Portal haters
I wonder how well some teflon bushings would work. we use them alot in the real offroad community. i'll see if I can find some and make a set.
07-10-2013, 03:08 PM | #9 |
| Re: Portal haters
does anybody else sell the CVA upgrade besides junfac directly. there sold out and I just bought more of the cheap stuff before doing research. rather by the kit than make them myself
07-10-2013, 03:21 PM | #10 |
| Re: Portal haters
c.k.r.c seems top have them. Not sure the link will work, but R1 CVA kit. edit the link and replace it with the CK-RC initials without the '-'. Found it on MammothHobbies too. Last edited by offroadace; 07-10-2013 at 03:25 PM. |
07-10-2013, 04:31 PM | #11 |
Rock Crawler Join Date: Jul 2012 Location: Brisbane, Australia
| Re: Portal haters
No issues on mine, easily 20+ hours of use, lots of hard binds, haven't broken anything in an the axles or any of the CVDs and I run four wheel steer.
07-10-2013, 04:47 PM | #12 |
| Re: Portal haters
I buy damn near everything from CKRC. looked all over and couldn't find them...thanks for the link the parts are in the mail |
07-10-2013, 04:48 PM | #13 |
| Re: Portal haters
Stock axles are not CVD, they are dog-bone. I lost at least 3 that I remember (I had 4WS also and failed front and rear) before I upgraded to modded XVD's. I bought 2 packs extra of the dog-bones just because it pissed me off so I would have spares before I upgraded. I don't expect to have any problems with the XVD's, just the small bearings now. |
07-10-2013, 10:18 PM | #14 |
| Re: Portal haters
i'm going to cut some teflon ones out next week hopefully i'll let you guys know the out come. once I get them in and run it. my jeep has afew teflon bushings that carry a real load and hold up great. so i think a RC crawler can definitly handle them
07-10-2013, 10:23 PM | #15 |
People have had good luck with the traxxas oilite bushing. I believe the part number is tra3775 and it's a direct fit. |
07-11-2013, 08:41 PM | #16 |
| Re: Portal haters
im in love with my R1 now that the dog bone is fixed. then this happened
07-11-2013, 11:50 PM | #17 |
| Re: Portal haters
That's impressive in that it totally deformed the rod ends before any of the drivetrain snapped.
07-12-2013, 07:43 AM | #18 |
| Re: Portal haters
yeah I thought I was screwed. changed out the rod ends put some loctite on abunch of stuff and I was back out in the yard crawling in under 45 mins...had to wait for a battery to charge.
07-12-2013, 01:54 PM | #19 | |
| Re: Portal haters Quote:
In any case, I'm surprised the stock drive shaft help up for you to even do that much damage. | |
07-12-2013, 02:55 PM | #20 |
| Re: Portal haters
it was ina a real crappy situation I should have just picked it up. once it was bound up I tried to get out of it and well....it didn't work.
Portal haters - Similar Threads | ||||
For all you cat haters.... | Slowkrawl | Chit Chat | 15 | 07-15-2011 07:12 PM |
Custom haters | White Stripe | Tires and Wheels | 1 | 01-18-2011 08:29 PM |
Haters for a few | bcrofts | Tires and Wheels | 32 | 06-28-2010 05:35 PM |
Why so many haters? | D-ran83 | General Crawlers | 114 | 11-30-2006 05:03 PM |
