07-22-2014, 03:18 PM | #1 |
Newbie Join Date: Feb 2013 Location: Chicago
| Carbon steel drive shafts
Is the shorter drive shaft the rear or front shaft? Thnx. KOH |
10-21-2016, 11:19 AM | #2 |
Pebble Pounder Join Date: Sep 2013 Location: Santa Cruz
| Re: Carbon steel drive shafts Looks like you never got an answer on this question. I'd dig hearing whether the short goes up front or in the rear as well. The stock driveshafts are the same length. Eyeballing the underside of the R1 chassis, it looks like the distance is about the same between the front axle to tranny and rear axle to tranny. I guess it's time to measure. |
10-21-2016, 01:25 PM | #3 |
Did some testing and the short Junfac seems too short to rely on for my axle set-up. Ordered a Junfac CC01 driveshaft off Amazon that's the same length (107-142mm) as the longer one in the R1 package.
10-21-2016, 08:52 PM | #4 |
If you buy the factory upgrade kit the shorter is for the rear (93 to 105). That said I blew out my rear carbon steel and replaced it with the plastic stocker, which now has more packs on it vs the failed one, meanwhile the front carbon steel takes a beating and keeps running strong. Hang up and Drive |
10-22-2016, 10:08 AM | #5 | |
| Re: Carbon steel drive shafts Quote:
10-22-2016, 10:56 AM | #6 |
Saw that, that was my reason to upgrade. Just ran 3 more packs, shafts are fine , blew 3 bearings , my last cvd and popped a tire off the beadlocks Make that 4 bearings and 2 axle pins ! These ruptures have so much grip and side bite. The Tekin 17.5 redline I'm using is perfect torque and wheelspeed with stock gearing Hang up and Drive Last edited by mikemcE; 10-22-2016 at 12:49 PM. |
10-23-2016, 10:14 AM | #7 | |
10-23-2016, 10:56 AM | #8 |
Stock....12? Hang up and Drive |
10-23-2016, 11:07 AM | #9 |
| Re: Carbon steel drive shafts |
10-23-2016, 11:27 AM | #10 |
Zero cogging due to the sensor Hang up and Drive |
Carbon steel drive shafts - Similar Threads | ||||
STRC carbon steel universal axle drive shaft set | mr lee | Axial SCX-10 | 1 | 04-10-2014 04:45 AM |
Junfac Hardened Carbon Steel Drive Shafts? | STANG KILLA SS | Axial SCX-10 | 20 | 06-10-2011 08:54 PM |
Tamiya carbon steel propeller shafts out now | Bok | Tamiya CR-01 | 7 | 12-24-2008 05:52 AM |
