04-19-2015, 11:43 PM | #1 |
Newbie Join Date: Apr 2015 Location: Penticton BC
| R1 hop up companies
Hey R1 guys. Please list the companies that you know of that make hop ups for th R1, I ordered one and I would like to get all my Ducks in a row before I do the build
04-20-2015, 05:51 PM | #2 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
| Re: R1 hop up companies
The first thing I would upgrade are the axleshafts from the portal gearboxes to the steering knuckle since the stock ones are so weak. Don't waste your money on the g-made cvd's, they aren't much better. I haven't ran these but they look like a good option since you gain strength and steering angle. DravTech presents a sneak peak on the Gmade R1 Wrapter The other option is to use RC4WD xvds which are stronger than stock but don't gain as much steering angle as wraith parts. I'm running d40 xvds in mine with t-rex high clearance knuckles but these parts are hard to find after rc4wd probably got rid of them in the mystery boxes GMade R1 Axle Shaft to XVD mod The next upgrade is the bearings in the portal gearboxes. DravTech made his adapters so you can fit bigger bearings which should help or you can get bushings. |
04-21-2015, 09:49 PM | #3 |
Quarry Creeper Join Date: May 2006 Location: san diego
if you are asking for a oem parts from different manufactures i found boom racing, they are japan, BUT hey the R1 is S. Korean. i found the boom racing pretty good products. here is what i did so far. boom racing -steering knuckle -front hub carrier - rear axle lock out -front & rear lower links- (on these i did drill out the threads and use bolt and nut. ) -skid plate i used the gmade upper link- Gma51123S -skids -servo mount mip scx10 drive lines. r1 boom racing | eBay |
05-19-2015, 08:58 PM | #4 |
Pebble Pounder Join Date: Mar 2014 Location: brainerd
does any one make hop up portal gears? iv shreded 4 of em so far and never broke a shaft dual 45t motors on 4s with 2.2 xl boggers and i crawl/bash
05-20-2015, 10:20 AM | #5 |
Rock Crawler Join Date: Oct 2012 Location: Garden Grove
I'd be interested in that as well. Attempting a truck rebuilt and will be using the portals. It's going to be big and heavy, and most likely more for show than go, but would still like to not tear these or the bearings up. |
05-20-2015, 10:51 PM | #6 |
| Re: R1 hop up companies |
05-20-2015, 10:54 PM | #7 | |
| Re: R1 hop up companies Quote:
With dual 45t motors on 4s with 2.2 tires. That alot torque and wheel speed on tiny bearings and pot metal gears. No aftermarket gears I know of. | |
05-24-2015, 07:25 PM | #8 |
| Re: R1 hop up companies iv been shreding off the portal gears i think its partially from failing bearings after taking them apart tho
05-24-2015, 10:12 PM | #9 |
Pebble Pounder Join Date: Sep 2008 Location: Vancouver Island, BC, Canada
the gear that sits right on top of the final drive gear in the xr10 tranny's is a perfect fit for the upper portal gear, but of course, the teeth are not the same.. if someone knows if there is a berg gear or other gear that is the same as the xr pitch that will fit into the lower portal then problem solved.. kinda.. replace the bearings with bushings?
R1 hop up companies - Similar Threads | ||||
RC tires companies | kind325 | Tires and Wheels | 3 | 01-22-2015 07:58 PM |
Stocks in RC companies | drtrydr2000 | Chit Chat | 4 | 02-24-2011 02:04 PM |
2 Motor's from various companies, it will be ok ? | nusha | Newbie General | 7 | 12-18-2009 03:45 AM |
