06-02-2015, 09:46 PM | #1 |
Newbie Join Date: May 2014 Location: Sydney
| 4 Link Sawback?
Anyone see this? : rcMart Blog – Flex your Sawback! Seems easy to do, hate those rock solid leaf springs on my Sawback. Will it really make that much difference? Searched through the forums, doesn't seem like there's a performance report. |
06-03-2015, 11:53 PM | #2 |
Newbie Join Date: Apr 2015 Location: Oregon
| Re: 4 Link Sawback?
Do a google search also. Did you take your shocks off? That Gives you a bit more travel
06-04-2015, 02:23 AM | #3 |
Pebble Pounder Join Date: Apr 2013 Location: Bonney Lake
| Re: 4 Link Sawback?
Anti squat leaves a bit to be desired but it should give you more flex since its 4 link vs leaf. Looks like a solid upgrade if you don't like leafs. You could also mod your leafs at the mounting points for a bit more flex and or try shooter shackles. Could also try softer leafs too. Sent from the clouds |
06-26-2015, 11:58 PM | #4 |
Newbie Join Date: Jan 2015 Location: chico
| Re: 4 Link Sawback?
So I have a lot of time and effort into my sawback. I immediately ditched the stock tranny plate and went with the SCALERFAB flat plate steel tray. It gives you appox 4 to 5mm's more clearance. I used some traxxas Emaxx links of both pumpkins to start the process. My goal was not to eliminate the springs but to stop the axle wrap and leaf bending/breakage. I also mount 3 3/4 lunford Ti turnbuckles I had in my LOSI 22T stash. These links at all 4 corners mount to inside of shock mounts and then I drilled a mount stop on all four corners of sheet steel tranny plate. So I have 2 holes in tranny plate for pumpkin top links and 1 hole at each corner of tranny plate for all 4 of the lower links coming from the shock lower mounts. Almost zero wrapping. NO bent springs and I can now run the large single leaf and also did the Chino Mod....Still not the articulation of my SCX10 but this thing climbs with them all day long
06-29-2015, 08:44 PM | #5 |
Rock Crawler Join Date: Dec 2014 Location: In the sticks
| Re: 4 Link Sawback?
Reversing the front shackles also helps with flex. The frontend of mine actually has about 3/4" more travel than what's pictured, plus moving the shackles to the rear of the spring helps stop the frame from hanging up on everything. It does get fairly involved. As you can see in the last picture it will throw your pinion angle way off, but you can file the leaf saddles to the proper angle to fix this problem.
07-01-2015, 10:25 AM | #6 |
| Re: 4 Link Sawback?
So I like your idea and will give it a try....I believe doing the"chino" mod and grinding the spring ends accomplishes same thing....looks like you are running all 3 leafs....with my link configuration, I only have to run 1 main leaf because axle wrap is eliminated ...also u can adjust pinion angle by using turnbuckle wrench on outside lower links...I am going to try your suggestion though.....
07-01-2015, 08:05 PM | #7 | |
| Re: 4 Link Sawback? Quote:
4 Link Sawback? - Similar Threads | ||||
My Sawback | 06ToasterBox | G-Made Sawback | 86 | 01-17-2020 01:27 PM |
Sawback vs. Sawback Sports | scaled | G-Made Sawback | 6 | 04-01-2015 09:04 PM |
4 Link Sawback | Saabonthis | G-Made Sawback | 2 | 01-18-2015 10:52 AM |
4-link Sawback | Jacabbysal | G-Made Sawback | 8 | 03-05-2014 11:45 PM |
Wild Willy On A Sawback [Sawback Solo Run] | ifulg | G-Made Sawback | 1 | 12-24-2013 08:06 PM |
