01-13-2017, 02:01 PM | #1 |
Newbie Join Date: Jan 2017 Location: Greece
| R1 looks crooked at resting position
Hello everybody ! First post here sice i got my r1 bout 3 days ago . There is a wierd thing going on that the chassis leans to one side at the front and the fron shock looks a bit off compared to the other one : Here is a link https://we.tl/XuwNyrSFGJ can someone please tell me if this is normal? Sincerely yours Nick |
01-13-2017, 02:15 PM | #2 |
Where are the front shocks mounted ? Hang up and Drive Last edited by mikemcE; 01-13-2017 at 02:18 PM. |
01-13-2017, 04:49 PM | #3 |
| Re: R1 looks crooked at resting position
I had them exactly like your picture, if you click the link i provided ( cannott figure how to post pictures from my mobile) you can see exactly the problem
01-13-2017, 06:44 PM | #4 |
Post pictures thru tap a talk or a hosting site like fokti or Photobucket . When I looked the bottoms are hidden, that's why the ? If all mounted the same look at one of the balls for binding. I never used those shocks, don't think it's internal though Hang up and Drive |
01-13-2017, 11:00 PM | #5 |
The balls that connect to the center of the front axle where binding so i fixed that with a couple of 1mm spacers and i also rebuilt the shocks (really bad quality shocks imo) and the o-rings had too much friction . I greased them and everything was nice and springy after that . So i suppose the oring binding in conjuction with the ball binding created the problem. Can you recommend other suspensions? I also attach some photos through tapatalk (thanks for the info btw) Sent from my iPhone using Tapatalk |
01-14-2017, 07:07 AM | #6 |
I'm running the rear yeti shocks up front, and the fronts out back. My fronts are long and soft, the rears are shorter and firm, I'm running 30 weight fluid . Not a big fan of that style shock, I ran a set of rc4wd in the back and didn't like them Hang up and Drive Last edited by mikemcE; 01-14-2017 at 09:10 AM. |
01-14-2017, 08:48 AM | #7 |
| Re: R1 looks crooked at resting position Welcome Nick! The motor is mounted on that side, and with the shock design on the R1 (floating pistons) a little lean like that is normal. It is just where the weight is and won't hurt a thing. Standard shocks with an external coil spring can easily be retrofitted if you like. They can be tuned much more than the stock shocks. Take a ruler or caliper, measure from mounting point to mounting point of the shocks at full extension of the suspension, and that's the length shock you want. I believe 110mm or 120mm worked perfectly on mine, but measure to be sure. Good luck! |
01-14-2017, 08:52 AM | #8 |
Thank you very much everybody ! I did the full sprung setup and the r1 worked so much better ! Also i am 3d printing a full battery plate for the front to mount my lipo there and i hope this helps as well. Also i dont think the stock tires do it justice... ! Sent from my iPhone using Tapatalk |
01-15-2017, 07:19 PM | #9 |
Rock Stacker Join Date: Dec 2011 Location: Coaldale
What driveshafts is everyone running. Do yoh have a part number Sent from my SAMSUNG-SM-G891A using Tapatalk |
01-15-2017, 08:23 PM | #10 |
Stock plastic, I break the others from junfac Hang up and Drive |
01-16-2017, 02:32 AM | #11 |
How is it possible to break a metallic shaft like that ? i have already ordered the one gmade makes
01-16-2017, 07:45 AM | #12 |
I've been running a lot of lift in the rear, and my driveshaft angle is awful. I routinely shred only the upper socket, so I flip things. With the junfac at 18.00 a pop the plastic last longer and are 8.00 a pair. I've also eaten all 4cvds and went back to stock. These are the only weak areas I've run across Hang up and Drive |
01-17-2017, 03:27 PM | #13 | |
Pebble Pounder Join Date: Sep 2013 Location: Santa Cruz
| Re: R1 looks crooked at resting position Quote:
01-17-2017, 03:47 PM | #14 | |
Yep same place, but only the output side in the rear. What I do is. Replace one end, reverse shaft use replacement end and next time use other half.... I've actually gone back to the stockers and have less cost and breakage I do drive mine hard, that Tekin just keeps pulling ! Hang up and Drive | |
01-17-2017, 03:48 PM | #15 |
Pebble Pounder Join Date: Nov 2016 Location: Southern California
| Re: R1 looks crooked at resting position Like this!!?? I have blown thru at least 6 of these. |
01-18-2017, 01:22 PM | #16 | |
02-12-2017, 08:22 AM | #17 |
First day in the construction site with my r1 with xl super swampers ! Performed really well but i think it was lacking power ! I am on my own on this hobby and cant really compare and dont know what to expect from my crawer ! Any suggestions appreciated ! 55t trailbreaker motor , hobbywing speedo . Sent from my iPhone using Tapatalk |
02-12-2017, 08:40 AM | #18 |
Im running a tekin 17.5 sensored ..... that is close to a 35t brushed. Your 55 is slower and more torquey you could go to a 35t for more speed Hang up and Drive |
02-12-2017, 03:24 PM | #19 |
It is not speed i am looking for i needed more push . It got stack easy. Sent from my iPhone using Tapatalk |
06-29-2017, 10:30 AM | #20 |
Quarry Creeper Join Date: Nov 2013 Location: Huntsville
Stock shocks work just fine as long as you run them without oil!
R1 looks crooked at resting position - Similar Threads | ||||
Crooked then Straight | RickM | Axial AX-10 Scorpion | 9 | 11-15-2010 03:31 PM |
4 linked it and I think its crooked | RickM | Axial AX-10 Scorpion | 10 | 03-10-2010 11:51 AM |
crooked axal | jwilli2213 | Axial AX-10 Scorpion | 11 | 02-12-2008 10:29 AM |
DX6, replacing the 2 position gear and aux switches for 3 position? | 666 | Electronics | 10 | 04-30-2007 11:23 PM |
