02-12-2017, 03:27 PM | #1 |
Newbie Join Date: Jan 2017 Location: Greece
| Is r1 worth it ?
I am asking if it worth it to keep investing in the r1 or i should start a new project all along. I have already done a couple of mods and i would like to know what is the long term experience you all have with it. I got it as a starter and "for fun" but i got hooked and i would like to know if it is worth investing or i should go for a moa crawler or a high quality scaler. And if yes what are your proposals ! Nick Sent from my iPhone using Tapatalk |
02-12-2017, 04:26 PM | #2 |
| Is r1 worth it ?
The R1 is a fun rig..... I love mine but it cost me a ton to get where I am, and it really isn't a crawler but a bouncer. I've done tires and settled with a set of jconcepts Ruptures, great traction with stock foams. Small bearings and sloppy gears in the portals. If you really want to crawl, think of a rig with better axles..... scx10 2 is a starter. I also have a Bully2 MOA as a serious crawler, much more $$$ and ability . Hang up and Drive |
02-12-2017, 05:30 PM | #3 |
| Re: Is r1 worth it ?
I also considered the bully because crawling is what i want . What combo would you recommend and how much will it cost me to build a decent one? Keep in mind that where i live there is no crawling scene and i pretty much do it on my own. I have found some great spots. My main rc thing is racing 1/10 off road . Sent from my iPhone using Tapatalk |
02-12-2017, 06:47 PM | #4 |
| Is r1 worth it ?
I'm in the same boat, spend some $$$ on the R1 to address the shortcomings. Biggest is awful Turning radius ...... I went to 4ws, two servos and all the aluminum parts. I upgraded shocks and am still playing with them. I'm running axial yeti fronts on my rear and a set of 5" prolines up front. Light oil and springs..... I'm running a sensored motor with a Holmes hobby BLE, great drag brakes. If yo double your $$ the R1 will last. Outside of regular small bearings failing and an occasional rear driveshaft failure(extreme angle) this rig is bulletproof fun, just not comping . Hang up and Drive Last edited by mikemcE; 02-13-2017 at 05:15 AM. |
02-12-2017, 09:23 PM | #5 |
Pebble Pounder Join Date: Nov 2016 Location: Southern California
Agree with Mikemce. I dumped a lot of cash at the R1 to get where I am with it, mainly to keep up with my buddies LCC. It is a fun rig and I learned a lot through out the build. Went with an XR10 for serious crawling. Good luck!! Sent from my iPhone using Tapatalk |
02-13-2017, 04:25 AM | #6 |
Rock Stacker Join Date: Nov 2016 Location: Australia
If rock crawling is not a big seen where you are and your not planning on competition then id stick with your R1 and upgrade what breaks. If you start over with say an scx10 2 or a bully then the cost of outlay plus upgrades will be much higher That being said i have not had my R1 for long so may change my mind soon lol |
02-13-2017, 11:24 AM | #7 |
So far i got 4ws new tyres and a couple of aluminium parts .. It works kinda cool but definately more like a scaler not a proper crawler. Sent from my iPhone using Tapatalk |
02-13-2017, 07:26 PM | #8 |
I used a $12 R1 cage and the rest was Axial products. So no portal axles but parts availability is abundant...but not needed. Depends on your budget.
02-21-2017, 02:51 PM | #9 |
Pebble Pounder Join Date: Sep 2013 Location: Santa Cruz
I've easily doubled my initial cost on my original RTR R1 and have a rig that has not failed me yet, all aluminum bits, a Holmes Hobby ESC and brushed motor, 4 wheel steering, a Gmade DIG unit, new tires/wheels, and 3 hi-tek servos to control it all. Basically - I've got around $800-900 invested in the rig. My wife thinks it's a third of that; no idea how that happened. |
Is r1 worth it ? - Similar Threads | ||||
What are these worth about. | WestTxRc | Redcat Crawlers | 5 | 11-20-2011 07:08 AM |
Is it worth it? | WestTxRc | Axial Wraith | 20 | 11-17-2011 07:29 PM |
Is it worth it? | Voteban | General Crawlers | 9 | 04-08-2010 09:58 PM |
what's it worth? | doomdog666 | Tamiya Clod Buster | 6 | 11-12-2009 08:34 PM |
are they worth it | BC Crawler | RC4WD Bully | 20 | 09-17-2009 05:07 PM |
