Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: Coming soon .....GMADE GOM-GR1 Rock Buggy
Old 12-08-2017, 07:44 PM   #541
Default Re: Coming soon .....GMADE GOM-GR1 Rock Buggy
Does anyone have the WMS to WMS measurement for the axles? I've searched around and only find the overall width ( which includes the tires)
BigSki is offline   Reply With Quote
Old 12-10-2017, 03:51 PM   #542
First time running today. Performed as well as I expected it to which was ace.
Dig stayed engaged a couple of times but a gentle tap on reverse sorts that out so it wasn't an issue and soon became habit. My summit is the same when shifting lo/hi
keirravn is offline   Reply With Quote
Old 12-10-2017, 05:40 PM   #543
Harleys video building one, he compares ar60 and iirc, it was 1" wider overall then ar60s.
84yoda is offline   Reply With Quote
Old 12-11-2017, 12:00 AM   #544
I got same issue. I think the dig saft spring on transfer case is too weak. That's bad, if driving crawling comp...
Pisepise is offline   Reply With Quote
Old 12-11-2017, 01:29 AM   #545
It may wear in though. Time will tell
Old 12-11-2017, 03:07 AM   #546
Ordered mine yesterday, along with a HW1080. This is going to be my budget crawler/mudder I think. With cheap bits I don't mind getting it stuck in deep mud. Got 2 x pdi 6221 to go in and a 550 15T can. Think I will have a go at making my own Ali panels...just done my bomber...not too bad though I struggled with the bonnet...was only using tin snips though.
I won't start this until Xmas.. .it's my present to myself. First gmade model.
I don't have a 3 position 3rd channel at the moment...so I was thinking of setting endpoints so I will have 1st and 2nd on the button...then if I need dig just change endpoints quickly....any other tips...im still new to this...~3 months on kits..
thewildblue77 is offline   Reply With Quote
Old 12-11-2017, 05:53 AM   #547
That all sounds good, except the part about it being a mudder. The slot the shifter slides in allows dirt/debris to get trapped inside the cavity and screw up the shifting movement. I'm sure someone will come up with a solution, but I haven't seen it yet.
TooOldForThis is offline   Reply With Quote
Old 12-11-2017, 06:29 AM   #548
Bugger...so at that point it's just stay in gear and hope for the best...Is it easy to clear out...i know it's something 52 screws to take apart...but can you access inside without having to do this?
Old 12-11-2017, 07:06 AM   #549
"Easy" isn't a word that comes up much when talking about GOM maintenance. At minimum you'd have to take the interior out just to get access, which means also taking the rollcage apart.
Old 12-11-2017, 09:23 AM   #550
So its worse than the bomber...I tend to run without interiors....is that possible with this...prefer ease of access over aesthetics....similar to how I like my women...haha
Old 12-11-2017, 09:45 AM   #551
If you didn't install the interior... you could probably remove the transmission tunnel cover (that ties transmission to transfer case & covers shift rods) easily with only needing to remove your roof panel, & maybe the roof section of the cage...
MELKORsXJ is offline   Reply With Quote
Old 12-11-2017, 10:32 AM   #552
You can remove the entire cage as a single piece with 14 screws I think it was that I counted.
2x the screw behind the top of the rear shocks (1 each side)
8x screws at the bottom behind the middle side panel (4 each side)
2x screw up where the hood/bonnet and A-pillar meet (1 each side)
2x screws where the front of the cage meets the hood/bonnet (windshield area).
soze is online now   Reply With Quote
Old 12-12-2017, 04:59 AM   #553
I’m putting a quicker motor in mine, should be easy with only having to remove the front to get the motor out.
RcAnt is offline   Reply With Quote
Old 12-12-2017, 10:58 AM   #554
What are you putting in ?
My kit arrived today ready for my xmas build...but the 550 15T was out of stock so Ive got a 540 20T and 550 21T titan to try at the moment.
Old 12-12-2017, 11:01 AM   #555
I’ve put a 13T in, speed isn’t bad but not over the top
Old 12-13-2017, 01:30 PM   #556
Originally Posted by RcAnt View Post
Think I’ve worked it out
Looking nice!
Where you get those seat belts?
Old 12-13-2017, 01:31 PM   #557
They are Yeah Racing ones from RCMart
Old 12-19-2017, 04:16 AM   #558
So my son saw my kit and has decided he wants one for xmas. So come Xmas day we have 2 GOMs to build. He has decided he wants to run the 540 20T, so Im going to be on the 21T 550 unless the 15T arrives...
Old 12-19-2017, 04:19 AM   #559
Default Coming soon .....GMADE GOM-GR1 Rock Buggy
I’m using a 540 13t in mine which seems about right
Old 12-19-2017, 04:22 AM   #560
Still having issues with the 2 speed and dig and it didn’t want to change at all after a bit (lot) of mud.
Tags
gmade, gom
Coming soon .....GMADE GOM-GR1 Rock Buggy - Similar Threads
Malin's new Gmade R1 Rock Buggy BentKa G-Made Crawlers 59 09-28-2012 06:30 PM
