02-28-2018, 10:57 AM | #701 |
Rock Stacker Join Date: Jun 2016 Location: England
| Re: Coming soon .....GMADE GOM-GR1 Rock Buggy
I wonder if metal gears would help (if they are machined properly) Sent from my iPhone using Tapatalk |
02-28-2018, 11:12 AM | #702 |
Rock Stacker Join Date: Feb 2018 Location: Ozarks
| Re: Coming soon .....GMADE GOM-GR1 Rock Buggy |
02-28-2018, 12:48 PM | #703 |
Does anyone know if a Tekin ROC412 will fit in a GOM? My kit hasn't arrived yet. Motor Diameter: 35.8mm / 1.41" Motor Length: 52.5mm / 2.10" Thanks Last edited by OzarkCrawler; 02-28-2018 at 01:15 PM. |
02-28-2018, 01:59 PM | #704 |
Pebble Pounder Join Date: Jul 2013 Location: Manchester,UK.
that should fit without issue. from what I've seen its only when you hit 550 dimensions that you'll run into an issue.
02-28-2018, 03:27 PM | #705 | |
| Re: Coming soon .....GMADE GOM-GR1 Rock Buggy I'm definitely a GMade owner now. I'll start a build thread soon. Quote:
02-28-2018, 05:54 PM | #706 | |
| Re: Coming soon .....GMADE GOM-GR1 Rock Buggy Quote:
Looks like you might have got your kit from the same seller I got mine from on Ebay, he (allmyrcs) seems to be the only one auctioning them off. I forgot how different Ebay has become, seems like there's hardly any auctions anymore. Welcome to the club! | |
03-01-2018, 12:21 PM | #707 | |
Newbie Join Date: Nov 2017 Location: Eureka
03-01-2018, 12:43 PM | #708 |
03-01-2018, 02:05 PM | #709 | |
Though I do have 2 retainers from a Tamiya axle set which is much thinner but its 3 loops, its too wide and would need to be cut down some. For now I'm gonna try some CA glue I just fitted some 2x12mm pins in the CVA's last night and took some measurements and pictures HumboldtEF's Gmade Gom Build | |
03-01-2018, 02:16 PM | #710 | |
Thanks for checking that! Sent from my iPhone using Tapatalk | |
03-01-2018, 02:41 PM | #711 |
03-01-2018, 08:23 PM | #712 |
Quarry Creeper Join Date: Feb 2009 Location: Houston
Would heat shrink tubing over the snap ring do the trick?
03-02-2018, 03:47 AM | #713 |
Quarry Creeper Join Date: Sep 2017 Location: UK
Well the pin on the new CVA has lasted over 35mins now...so that's a good sign. However the 20T died in my son's GOM last night...so he is getting my 20T and I've put the mamba X and 3800 in...running on a 12T pinion and it will be 3S. Be good to run the aux mode. It's a bit tight in there though... Sent from my SM-G935F using Tapatalk |
03-02-2018, 05:48 AM | #714 |
Rock Crawler Join Date: Apr 2017 Location: Northeast PA
So after reading these recent posts, what I gather is the Gmade CVDs are pretty terrible. Is anyone running theirs hard and NOT having constant breakage? I've already switched all the driveshafts over to Gmade/Junfac CVDs but haven't driven it much since. If breakage at 35 minutes is "good", this one is gonna be put on shelf queen status. I'm interested to hear how Humboldt's 2x12mm pins work out. |
03-02-2018, 06:28 AM | #715 |
03-02-2018, 06:44 AM | #716 |
Pins, cages and gearshifts are the main issues so far...other than that love it. To be fair with the washer mod I nearly always get a clean shift now. I think that it could be batches of the CVA that may have issues. My first set were pre-assembled. The next set Ive had to build myself. Its now brushless so I will see how it copes.... |
03-02-2018, 09:17 AM | #717 |
Yeah I think I was focusing on the retaining clip a lot more that I probably should have. When I heard the pins were coming loose I assumed the clip was letting them loose but now I think what might be happening first is the pin is snapping. I just did a very, very unscientific strength test where I held the pins (stock and new longer pins) with two sets of pliers and broke them, they both seemed to break with the same force. I kind of expected the stock pin to feel brittle but it didn't stand out. Anyway I think (and hope) it may just be down to length and the amount of engagement at the axle cup. Imagine for a moment the (shorter stock) pin moving around, as it shifts to one end the other end might be left with so little engagement, maybe .5mm or so that when it transmits force into the pin its ready to shear it off, like hitting it with a blade compared to a hammer (exaggeration). Having more engagement here should in theory spread the forces out much better. Alright enough theory I need to put these new pins thought its paces. Also I took a few pictures of the "washer mod", I thought it may help someone as I've only heard it described so far. Washers are placed between the shift slider cover with the intented of allowing a bit of slop in the slide mechanism and to help improve shifting. My washers measured 1/32" thick. Its the only thing that I've changed with the shifter and it seems to be pretty consistent, I still get an occasional miss-shift though. Last edited by HumboldtEF; 04-15-2018 at 12:58 PM. |
03-02-2018, 11:42 AM | #718 |
My CVA's arrived today, they came unassembled from RPP.
03-02-2018, 06:09 PM | #719 |
For those of us waiting for aluminum dig forks to return to stock, I received an email from Greg @ Active Powersports saying he expects them in around the end of the month. Just wanted to pass this along. Hopefully other vendors will be getting their stock around the same time. Last edited by OzarkCrawler; 03-02-2018 at 06:39 PM. |
03-02-2018, 10:35 PM | #720 | |
Active Powersports? Have you ordered from them before? I've heard horror stories about them. Especially since their site isn't accurate as far as what is in stock and what isn't, but still lets you order without any indication it's out of stock. My general rule of thumb is that if it has never been in stock on Junfac, other vendors most likely haven't gotten them yet until Junfac lists them in stock. What I do see recently listed on Junfac is the stock Hi/Lo/Dig shift fork parts. This is likely for the RTR GOM as it comes as a single speed. Last edited by soze; 03-02-2018 at 10:38 PM. | |
Tags |
gmade, gom |
Coming soon .....GMADE GOM-GR1 Rock Buggy - Similar Threads | ||||
Malin's new Gmade R1 Rock Buggy | BentKa | G-Made Crawlers | 59 | 09-28-2012 06:30 PM |
