Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: Soze's GMADE GOM GR01 Build
Old 12-01-2017, 05:54 PM   #41
Default Re: Soze's GMADE GOM GR01 Build
Originally Posted by 99crawler View Post
Soze, just started my build and just finished the axles. Did you experience any gear mesh issues? One of my axles gear mesh is very rough and not smooth at all. I have tore it down once and re-greased with no luck. Appreciate any suggestions.
I did not run into any gear mesh issues, but your problem could possibly be that you put in your diff locker in backwards. Make sure the rounded side of the diff locker tab is pointed towards the case and away from the bevel gear. I point it out in my build video.
https://youtu.be/BdzVMEqeBBc?t=10m56s
soze is offline   Reply With Quote
Old 12-03-2017, 08:19 AM   #42
I had this problem on one axle. I took it apart and closely inspected everything, re-greased really well, but I never did figure out what was causing it. As it turns out, it could only be felt when spinning by hand because I haven't noticed it since that early assembly step (my GOM is completed and drives). I actually forgot about it until I read your post.
Obviously we don't know if mine was as bad as yours is, but you might be OK to continue with assembly and see how it drives.
TooOldForThis is offline   Reply With Quote
Old 12-05-2017, 02:59 PM   #43
After multiple rebuilds of the axle, found some minute, residual amount of plastic on the diff case (from the plastic tree) that was causing it to rub against the actual bevel gear. Drove me nuts not being able to get a smooth feel when rotating by hand. Nevertheless, after some finish work on the diff case I was able to get it a lot smoother. Thanks all for the advise. Now to get back to building.
99crawler is offline   Reply With Quote
Old 01-06-2018, 03:40 PM   #44
Finally decided on a driver for my GOM.
Tunnel Rat from GI JOE Sigma 6 line
On Another note... I spent time thinking about how to protect the shifter slot for the 2-speed transmission.
Do I cover it with lexan, somehow make a rubber boot?
In the end, my head was already fatigued from work and I just thought... 3M Tape.... piece of felt.... it'll work. LOL
Old 01-06-2018, 10:34 PM   #45
Finally installed the last 2 upgrade parts that I have on hand. (Although I'll probably upgrade some more parts as they are released in the future).
First was the GMADE Aluminum Skid Plate (available on eBay) to give the bottom a little more protection and give the bottom sides an angled flat surface to prevent getting hung up. It also has a minor protrusion to protect a little of the 2-speed transmission area.
Also got around to installing the GMADE CVA/CVDs. Holy Moly what a difference in steering angle!!! I'm going to need to spend some time adjusting my steering end points.
Old 01-06-2018, 11:45 PM   #46
My fave driver figure ever - I normally can't stand any of them... very nice looking GOM!
durok is online now   Reply With Quote
Old 01-07-2018, 11:27 AM   #47
Tiny Truck Hoarder
HumboldtEF's Avatar
Wow that is a pretty big difference in steering angle from those Uni's.
I dont think that felt mod is bad at all, it should have good flexibility and do a good job of keeping crud out.
Great work Soze!
HumboldtEF is offline   Reply With Quote
Old 01-22-2018, 02:23 PM   #48
Bloody hell, I'll never have any money. Having read through this thread I now need one of these!
Old n ratty is offline   Reply With Quote
Old 01-27-2018, 07:21 PM   #49
Soze, any tips to improve the shifter to be smoother? Can't get mine to be smooth without the servo stressing. Appreciate any input.
Old 02-07-2018, 05:08 PM   #50
I just got mine and have yet to start building it.
Have you been able to run it and find any weak spots or other issues?
Catbox is offline   Reply With Quote
Old 02-11-2018, 08:49 PM   #51
Do those shocks contain oil or just grease damped? Cheers.
pullstarter is offline   Reply With Quote
Old 02-11-2018, 10:33 PM   #52
Oil shocks
Old 02-11-2018, 10:34 PM   #53
Got in a test run today. Went ok, but I need to find something a little more challenging for it. Just haven't had time to really get out.
Old 02-11-2018, 10:37 PM   #54
I don't know what to tell you other than adjusting the end points the best you can. I use a Savox 254mg so plenty of power.
I also greased the groove for the shifter guide top and bottom.
One thing I do have is the aluminum Hi/Lo shift fork. I plan to get the aluminum dig shift fork when that's available too.
Old 02-12-2018, 01:18 AM   #55
So, I went out hoping to test the truck out at a local spot that I found people talking about on the forums. Head out there today and discovered that the spot is now a paved road.
Ended up just taking it for a light run at the community trail with what little time I had left.
https://youtu.be/fv1onIJeO54
Old 02-22-2018, 06:57 PM   #56
Great looking build Soze. How is the SkyRC Ares Pro motor working for you?
OzarkCrawler is offline   Reply With Quote
Old 02-23-2018, 10:20 AM   #57
It's actually working out pretty well. I think I'm just going to keep it in there. It's got enough speed on 2S and since it's sensored, it works fine for crawling.
Old 02-24-2018, 07:35 AM   #58
Originally Posted by soze View Post
Is this the 20mm long version?
Good to hear, I was thinking of trying the 9.5T/3700KV version when I get to building mine.
Old 02-24-2018, 09:56 AM   #59
Tiny Truck Hoarder
HumboldtEF's Avatar
The stock servo horn is 20mm
I went for the 24mm version just in case I ever needed the 24mm hole but I am currently using the 20mm hole. A bit of material needs to be trimmed off so the longer 24mm horn doesn't hit.
Old 02-24-2018, 10:07 AM   #60
Thanks Humboldt, don't have my kit yet but trying to put together my list of mods.
Soze's GMADE GOM GR01 Build - Similar Threads
Soze's GMade Sawback 4LS soze G-Made Sawback 23 12-31-2021 12:59 PM
Coming soon .....GMADE GOM-GR1 Rock Buggy big1717 G-Made Crawlers 951 05-12-2019 02:43 PM
Soze's MST CFX-W Build soze Max Speed Technology CFX 90 01-31-2019 01:02 AM
New Gmade USA GOM Rock Buggy Kit - In Stock! RPP Hobby RPP Hobby 0 10-05-2017 10:30 AM
New Gmade USA GOM Rock Buggy Kit - Open for Pre-Order! RPP Hobby RPP Hobby 0 08-31-2017 10:17 AM
