Universals for a GOM? You bet! 2 Attachment(s) So the junfac mod didn't work, and I was tired of breaking and spitting pins. Tried most everything. I love the truck, just need reliable axles. Fortunately I have quite a few parts sitting around from other builds. Long story short: Axial XR front universal fits the short side front axle on a GOM(with minor trimming to the end) Axial AR60 long side is about a perfect match for the long side front axle on a GOM You will need these two parts, plus wraith knuckles and everything else works fine. Call it the xr/ar mod? "thumbsup" Also bent a rear axle, so now the GOM will be getting 4WS8) Attachment 373159 Attachment 373160 |
Re: Universals for a GOM? You bet! That’s good to know. This may be a daft question but is it not possible just to fit AR60s front and rear? Has anybody tried it yet? Sent from my iPhone using Tapatalk |
Re: Universals for a GOM? You bet! So by the JunFac mod do you mean the set screw that holds the pin in place? thats only part of the upgrade IMO Another important mod for strengthening the CVA's is to get a longer pin (12mm). But this is also good info to know. Quote:
EDIT: http://www.rccrawler.com/forum/g-mad...k-70s-gom.html and I cant find the other. |
Re: Universals for a GOM? You bet! Quote:
Iv fitted the ar60 ,..it’s definitely not a direct fit , the shock mount position are too narrow and they have to mounted outboard , the truss needs to be shortened to make space for the Panhard mount and all the links needs adjusting (i think) , I’m waiting for some threaded bar at the moment soon as that comes I should be able to get it done . I personally think the slightly narrower stance you get from the ar60 looks more realistic for scale though [emoji106] |
Re: Universals for a GOM? You bet! Good Info. I'll probably try the set screw mod + 12mm pins first. |
Also do not want AR60 axle housings. I like the currie looking gmade axles. The XR/AR mod does the trick for me. |
Re: Universals for a GOM? You bet! Any chance of of putting the AXA part numbers up so we can be sure of what exactly is required... :-) |
Re: Universals for a GOM? You bet! Ok, I might actually try this now, or at least gather parts for it in case my GOM ones die. How are the positioning of the links with the Wraith knuckles vs the GOM knuckles? Pictures of it all put together with steering links? |
Re: Universals for a GOM? You bet! Been busy fellows sorry. However I am adding rear steer to my GOM. With the same mod. I have the parts. Next week for certain. will post parts and pictures"thumbsup" |
Re: Universals for a GOM? You bet! Any updates? |
