11-20-2018, 10:13 PM | #1 |
Quarry Creeper Join Date: Feb 2017 Location: Adirondack Park
| Disappointing Sawback
I just finished putting together a Sawback kit, I can say I was a little disappointed with a few details of the kit. The shocks are only aluminum friction units, the Phillips hardware is so retro 80's and all plastic transmission gears. It just feels a bit cheesy. After doing what I feel are going to be the required upgrades I will not be that far from a RC4WD trail truck kit price. Now I don't hate the little jeep, was just surprised at the use of so many cost cutting parts,
11-20-2018, 11:14 PM | #2 |
| Re: Disappointing Sawback
It's one of GMADE's older kits. They didn't switch to full time hex screws until the GOM I believe. Other than that... give it a chance. It's actually a fun little truck to drive.
11-21-2018, 04:34 AM | #3 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
My brother in law has a Sawback. We trimmed the body a bit ,added 2.2s and Tekin 35 turn FXR combo and Hi-tech 7950 and it hasn't missed a lick in over a year. |
11-21-2018, 07:26 AM | #4 |
Fair knock on the shocks, but the Phillips hardware works fine. If you want to change you can get a stainless steel, hex head screw set for $25, but it's not a necessity. For the shocks you can get good, inexpensive units from GMade or other brands. As far as the plastic gears are concerned I can tell you they are strong. My Sawbacks lived through years of brushless and brushed abuse (not just use) and they are still going strong. They are plastic gears, but they are strong, plastic gears. You are still way under the price of an RC4WD kit. And the Sawback will be more durable and perform a hell of a lot better than anything from RC4WD.
11-21-2018, 08:39 AM | #5 |
Well I feel a little better now. It is going to be used at a tame indoor course.
11-27-2018, 08:14 PM | #6 | |
| Re: Disappointing Sawback Quote:
11-28-2018, 06:28 AM | #7 |
| Re: Disappointing Sawback I'm not sure what you mean by it "feels a bit cheesy." The Sawback is a very reliable truck. In my experience it's more reliable than my Axial and RC4WD vehicles. The only issue I ever experienced with my Sawback was bent leaf springs and that was mostly because of my driving. I put on anti-wrap links, changed my driving style a little and the truck hasn't severely bent a leaf spring since.
11-28-2018, 08:44 AM | #8 | |
11-28-2018, 09:06 AM | #9 |
| Re: Disappointing Sawback |
11-28-2018, 09:50 AM | #10 | |
EDIT: Here it is - GS01 Black Frame Set - JunFac There's always the option of stripping it and repainting them too. | |
11-28-2018, 12:18 PM | #11 |
| Re: Disappointing Sawback I know it is a perception thing, the finish, guess I am used to anodized or painted aluminum. I'm sure it does not effect the function. Time will tell how it holds up.
12-01-2018, 08:03 PM | #12 | |
Rock Stacker Join Date: Jan 2014 Location: online
The plastic trans gears are actully stronger than the axial scx10 trans. And the closed pinion is kinda nice. Philips bolts are cheap to replace, and not any worse than cheap hex hardware that likes to rust One thing that dose suck on the sawback is the factory wheels are junk, and he body is a bit to wide and needs lots of trimming for bigger tires. | |
12-01-2018, 08:07 PM | #13 |
Also the sawback can pull allot more weight than a scx10, vetarra, or trx4...
Disappointing Sawback - Similar Threads | ||||
Things to upgrade/watch out for Sawback 4LS & Sawback Sport | soze | G-Made Sawback | 2 | 02-28-2017 12:46 AM |
New Sawback | PatrickE | G-Made Sawback | 8 | 06-16-2016 10:00 PM |
Sawback vs. Sawback Sports | scaled | G-Made Sawback | 6 | 04-01-2015 09:04 PM |
Wild Willy On A Sawback [Sawback Solo Run] | ifulg | G-Made Sawback | 1 | 12-24-2013 08:06 PM |
Intellect 4600mah disappointing performance. | vtt | Electronics | 1 | 10-19-2008 03:18 PM |
