Thoughts anyone? Anyone have this same issue or a thought about why I'm having this issue? I mean I'd expect a little rubbing, but this is ridiculous. The tires are Pit Bulls and see the same height as the stock tire. https://uploads.tapatalk-cdn.com/201...33f659f755.jpg Sent from my iPhone using Tapatalk |
Re: Thoughts anyone? Same wheels as stock tires or different wheels with PitBulls? I'd say those Wheels have more off set. wider track. |
Re: Thoughts anyone? Incision wheels. Yes good point. I’d say the offsets are longer. So thinking if wheels aren’t sticking out so far, that will help with the clearance? Sent from my iPhone using Tapatalk |
Re: Thoughts anyone? Bust out the sawzall and get to cutting. |
Re: Thoughts anyone? Its prolly the offset on the wheels causing it Sent from my LG-M703 using Tapatalk |
Re: Thoughts anyone? I noticed it too when I built mine. Wan't bad with the stock parts, but when I went to larger/wider tires it was very apparent. 5mm spacers on the front 3 links works great. I run them on mine and I have no clearance issues with the fenders. |
Re: Thoughts anyone? Quote:
Awesome thanks!! Sent from my iPhone using Tapatalk |
