Komodo to R1 questions. I have read through alot of articles and haven't found exactly what I'm looking for. I was trying to switch over parts from my Komodo to an R1 chassis cause I like the tubers better than the scalers. I put it together and the drive shafts are too long. I found out they both use the same transmissions so I know that will work at least. I was wondering if maybe the drive shafts were just too long or if the links were too short. Has anyone else done this or tried too? Thanks for any info you can help with. I'm trying to get this solved before I get out and hit the rocks. Thanks again. |
Re: Komodo to R1 questions. Pics? I used just the chassis sides and my scx10 parts. Links and bracing were custom. |
Re: Komodo to R1 questions. Quote:
Re: Komodo to R1 questions. Well I was going to post pics but apparently I am not able to do that at this time for some reason. Prolly don't have enough posts. I wish I could remember my credentials for my old account cause it was good to go. I had to start all over lol.. |
Re: Komodo to R1 questions. Awesome. Here are some pics of what's going on with the axle.https://uploads.tapatalk-cdn.com/201...2da0dfcd32.jpghttps://uploads.tapatalk-cdn.com/201...9f58ec264a.jpg Sent from my SAMSUNG-SM-G930A using Tapatalk |
Re: Komodo to R1 questions. Thanks for the tip animalhippie. Now if I can just get to the posts required to see the classifieds I'll get this stuff built lol. Thanks again. Sent from my SAMSUNG-SM-G930A using Tapatalk |
Re: Komodo to R1 questions. If the geometry is good with the link lengths you have and you’re happy with them. I’d suggest cutting the shafts down to make them work. Or find/make longer links. |
Re: Komodo to R1 questions. Yeah I've noticed that I switched the screw around and it doesn't rub now but I don't get full shock travel up and down. But I installed the electronics and drove it around in the house and it seems to do just fine so far. I'm going to get it out as soon as it warms up here and see how it does outside. I have stuff to make some links so I'm thinking I may go ahead and do that anyway just to get a little more wheel base on it. |
Re: Komodo to R1 questions. Well after making some links and playing around with the geometry I had a set of wraith links I had ordered so I used the bent ones and straight made on bottom and it seems like it will work. I will be hopefully taking it out this week and getting some run time in to see how it all works out. |
Re: Komodo to R1 questions. Tanked the whole thing. Got a deal on everything but the chassis. So now my komodo is back together and getting all the nice scale bits. And the R1 is stockish. Do love the fact it has 4ws. I'll get some pics soon. Sent from my SAMSUNG-SM-G930A using Tapatalk |
