Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: Gmade Gom Battery Compartment Size?
Old 11-02-2019, 09:56 PM   #1
Default Gmade Gom Battery Compartment Size?
I've looked everywhere and can't seem to find specs on the battery compartment size of the Gmade Gom.
Or if you can provide which battery you are using and how much room you have left, I can look up the specs.
Thanks!
the.ronin is offline   Reply With Quote
Old 11-02-2019, 11:00 PM   #2
Default Re: Gmade Gom Battery Compartment Size?
I'm using a 2 cell hard pack
Sent from my SM-G965U using Tapatalk
aiden102408 is offline   Reply With Quote
Old 11-02-2019, 11:24 PM   #3
Thanks Aiden. However, I can't do much with just the cell count and the pack type. If you gave me the brand and mAh I can look up the dims.
For anyone else looking, I came across a build log (by RC Driver) that suggested they tried the MaxAmps 2S 5450mAh 120C (lol at that c rating) hard case and that was too big. This MaxAmps measures 137x45x18mm. They went on to say that the Onyx 2S 5400mAh 50C fit fine. The Onyx measures 132x42x29mm so I'm guessing the length and width were just a bit much for the MaxAmps.
Just want to be able to have a lipo ready for when the Gom arrives. Hope this is helpful to anyone else.
Old 11-06-2019, 11:49 AM   #4
Got my GOM
In case anyone else is wondering rough approximation of battery compartment size is 140mm length, 47mm wide, and 25mm tall. This makes it a tight fit length and width-wise. There may be some room on the height (~~2-3mm). Take into account the way the lipo leads come out of the battery too - sticking straight out the end will take up some length while coming somewhat out of the side might work better.
Old 11-06-2019, 08:31 PM   #5
Its looking like this Gens Ace 2S 4000mah is a really good fit ...
I'm also a huge fan of Tattu and Gens Ace lipos. They are bullet proof and their C ratings actually mean something.
Gmade Gom Battery Compartment Size? - Similar Threads
Rear sway bar hits battery/compartment Lavaheadache Vaterra Twin Hammers 3 01-02-2017 04:39 PM
Gmade R1 Battery Size Crawl On G-Made Crawlers 6 10-25-2016 07:19 PM
Battery compartment size Johan_Eriksson Axial RR10 Bomber 6 06-27-2016 10:32 AM
Turnigy 3S Packs dont fit in the battery compartment!!! djmaincheese Axial Yeti XL 10 11-26-2014 04:02 PM
Fixing a broken transmitter battery compartment sixty2 Electronics 0 10-08-2014 11:44 AM
