Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: Hello,Just bought a GS02 Bom
Old 01-03-2020, 09:51 AM   #1
Default Hello,Just bought a GS02 Bom
I have just took delivery of a new GS02 Bom kit. This is my first crawler so will more than likely be posting for advice/help/tips.
I am in the UK so there are very few Crawler clubs so this is just for Dad and son fun.
I went brushed set up so have a 35t dual bearing motor and HW 1080 esc.
Steering wise I am looking at 25kg metal case and gear servo.mid range again,will 25kg be ok?
Yet to look into cells,will go lipo, will I need 2s or 3s?
One early issue I did have was the Trans case. I read here about the issue with this and that later kits have revised parts,from jan 2019. When I ordered my kit I asked if it as been on the shelf for long? was told this stock was from nov 2019,so I ordered. QC card in kit showed nov 2018!!!!!! Rang the UK distributer who were great and new parts are being sent.
Hope I have not bored you guys and hope you are a good bunch of guys in the Gmade club : )
Gazzalene is offline   Reply With Quote
Old 01-03-2020, 09:53 AM   #2
Default Re: Hello,Just bought a GS02 Bom
I forgot to add, whats with the tyres covered in glitter? is this just my kit or normal?
I have washed with washing liquid and a bit is still present!
Old 01-03-2020, 10:47 AM   #3
Go with a 3S pack around 3300-3700mah or so. 25kg should be fine, and if you feel like you need more, it's easy to change out anyway. If you're doing some extreme climbing, some SSD Brass Knuckle weights will be good as well.
It's their mold release. It takes a while and several washings, but it will eventually come off. I didn't even bother as I went with Pro-Line TSL Swamper tires.
soze is offline   Reply With Quote
Old 01-03-2020, 04:44 PM   #4
https://youtu.be/_9KnnQO78i0
Injoy rc!!
SM-N971N Tapatalk
IZI-RC is offline   Reply With Quote
Old 01-19-2020, 07:29 AM   #5
Hi Gazzalene,
I just bought mine also and it dates back to 2018.
Do you know what parts were upgraded?
charlesd is offline   Reply With Quote
Old 01-19-2020, 11:49 AM   #6
Originally Posted by charlesd View Post
Hi Gazzalene,
Skid plate and the rear half of the transmission case that mounts on it.
QuesoDelDiablo is offline   Reply With Quote
Old 01-20-2020, 10:35 AM   #7
Thanks.
I wrote to G-made and they will be shipping the updated parts.
Old 01-26-2020, 11:55 AM   #8
Thanks.
I had the exact same problem and just wrote to them too. Did it fix the issue?
Liljun10 is offline   Reply With Quote
Old 01-26-2020, 12:32 PM   #9
I'm in Canada, so it will probably take 6 weeks before I receive the parts.
Sent from my SM-A530W using Tapatalk
Old 01-26-2020, 03:39 PM   #10
Hopefully that solves it. I was able to get my tran case in just the right spot that the clicking temporarily stopped.
Old 01-26-2020, 09:10 PM   #11
Updated case will solve it. You'll understand why when you see it. I have a picture in my BOM build thread.
Old 01-27-2020, 04:02 PM   #12
Dang! Your builds are impressive! Thanks for the inspiration.
Old 02-28-2020, 04:15 PM   #13
Well after receiving the new parts and installing them I had about 5 minutes of great crawling before the gears slipped again. To say i'm disappointed is an understatement. This was my first build and I really wanted to be a big fan of Gmade. Probably time to buy a RTR SCX10 or something so I can enjoy some crawling on the trails.
Old 02-28-2020, 04:20 PM   #14
That's interesting. I'm wondering how your gears managed to slip? If you got the new part there should be no separation at all unless your gears are already messed up from before.
Old 03-03-2020, 04:28 AM   #15
G-made finally answered me back that they will be shipping the updated parts. I guess they had problems with my e-mails.
Liljun10
Is it possible that the gears had a tooth that was damaged from before? The local retailer here has several of them with the old transmission and he has no problems.
Hello,Just bought a GS02 Bom - Similar Threads
bilinvic's Gmade GS02 BOM bilinvic G-Made Crawlers 152 01-02-2022 05:32 PM
1SLWMoFo’s GS02 Bom 1SLWMoFo G-Made Crawlers 31 08-27-2019 06:29 PM
GS02 BOM 2-speed info VR6 BeelzeDub G-Made Crawlers 4 06-17-2019 06:30 AM
GS02 Bom Old n ratty G-Made Crawlers 89 11-17-2018 01:53 AM
Gmade GS02 BOM questions m1009cucv G-Made Crawlers 2 10-26-2018 08:05 PM
