01-03-2020, 02:47 PM | #1 |
Rock Stacker Join Date: Nov 2019 Location: uk
| Shocks and teflon tape?
When using Teflon tape on the shocks is that only on the bottom thread or the cap also? How many turns are we talking about apx here, especially on the plastic cap, don`t want the use too much and split the cap. |
01-03-2020, 04:52 PM | #2 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
| Re: Shocks and teflon tape?
I've never used teflon tape on my shocks. I'm not even really clear on why someone would? Regardless, I think you've got the right idea about not using too much, I'd think 2 wraps should be about good.. |
01-04-2020, 03:05 AM | #3 |
Rock Stacker Join Date: Oct 2016 Location: Estonia
I have used teflon tape on shocks to stop leaks and I use it only on places where it leaks. Although when wrapping the bottom thread then oil is likely to exit through the hole where shock shaft passes through anyway since oil has to get pass the seals to get to bottom thread. So far have used only 1-2 wraps.
01-04-2020, 08:20 AM | #4 |
I tried Teflon tape once on plastic shocks and they leaked.
01-04-2020, 11:18 AM | #5 |
I use only enough to get it to cling to the threads. 1.5-2 wraps or so. A bit fiddly to do, but works great, I've got plastic Axial Icons that have been leak free for years. Really needed it on G-made's transition shocks. They leaked like crazy at the bottom threads...teflon tape solved it completely. |
01-04-2020, 11:56 AM | #6 |
OSRC, is it needed at the caps?
01-04-2020, 12:56 PM | #7 |
I depends on where its leaking from. If the cap leaks sure. I've only used this on shocks that leaked (I think all Axial lol) What shocks are these anyway? I assume something from Gmade. |
02-20-2020, 03:22 PM | #8 |
Whenever I've experienced a leaky shock, it's always the seal. I suppose some plastic shocks / shock caps could experience leaking at the threads though.
Shocks and teflon tape? - Similar Threads | ||||
Teflon or regular bearings? | dickwart | General Crawlers | 15 | 04-25-2010 07:50 PM |
teflon axle skids? | Kraqa | RC4WD Bully | 11 | 02-15-2010 05:06 PM |
teflon paint | punkuup5150 | General Crawlers | 1 | 01-19-2010 07:34 AM |
UHMW Tape/Teflon Tape/Teflon Tubing | mcho78 | General Crawlers | 5 | 03-25-2009 08:21 PM |
Teflon tubing | cyberhog05 | General Crawlers | 5 | 02-23-2008 11:58 PM |
