Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: Project Dragon Slayer GOM
Old 03-16-2020, 10:33 AM   #21
Moderator
JatoTheRipper's Avatar
Default Re: Project Dragon Slayer GOM
Wily Willy makes everything cooler. I approve!
Also, great sheet metal work. Do you have a forming brake?
Old 03-16-2020, 12:06 PM   #22
Thanks Jato!
I went back n forth on driver figure, but Wild Willy ended up perfect! I have a small brake I scored from Harbor Freight. I'm considering the combo Slip Roller, Sheer and Brake they have. I just need to make a bit of space in the shop since it's floor mounted. Maybe sell a motorcycle or two!
mewalsh100 is offline   Reply With Quote
Old 03-16-2020, 01:03 PM   #23
Moderator
Originally Posted by mewalsh100 View Post
Thanks Jato!
I paid too much for a cool, hand-painted Wild Willy. I want to put him in a rig, but I can never find the "right" truck.
Well you make good stuff with your tools!
Sell motorcycles? Stop swearing at me!
Old 03-16-2020, 03:40 PM   #24
Thanks man! If I did sell the motorcycles, I'd replace them with a Grom, or TWO! Smaller and easier to stash in a corner. My buddy and I would like to see if we can get a spec racing series going with them. That's why 2. One to keep clean and street and the other to thrash on the track. (He's got a huge parking lot for his business that we'd lay the course out on. Be nice to put the leathers and knee pucks back to use!
Old 03-19-2020, 07:15 AM   #25
Wild Willy looks great and the interior!
I have a 4' box & pan brake another good one to look at is the Harbor freight 3' brake with a little adjusting it would do well. I have hand sheared all my bodies since I started also HF has lots of coupons for discounts.
Keep up the great work!
Barndog Racing is offline   Reply With Quote
Old 03-19-2020, 01:25 PM   #26
Thanks for the heads up Brandon. Appreciate it!
Old 03-25-2020, 06:10 AM   #27
I've got most of the heavy lifting done on Project Dragon Slayer at this point. Still some small detail items to wrap up, including exhaust exits on right rear panel, fuel filler / dry break on left rear panel, LED's wired for the light pods, etc. Anxious to then get the panels shot with etching primer and the satin black finish coat. Weather temps and humidity are not cooperating though. But, gives me some time to wrap up those other details i suppose.
Old 03-25-2020, 09:30 AM   #28
Looking real good!
soze is offline   Reply With Quote
Old 03-25-2020, 11:26 AM   #29
Originally Posted by soze View Post
Looking real good!
Thanks soze - appreciate it!
Old 03-25-2020, 12:05 PM   #30
Nice. What does the stance look at ride height?
Szczerba is offline   Reply With Quote
Old 03-25-2020, 12:13 PM   #31
I'll snap a pic and post. But, I haven't even played with suspension settings yet.
Old 03-25-2020, 12:38 PM   #32
Here ya go Shane. Like I said though, I haven't even touched suspension yet. Bench thoughts are a little ride height out of the front, and up a bit in spring rate at the back.
Old 03-26-2020, 08:53 AM   #33
Doing some finishing detail touches prior to paint. Made this little dry break fueler out of some ABS, small cap screws. I plan on masking off the fuel inlet openings prior to paint so that they remain raw aluminum. I still need to figure out the exhaust tips, exits on the right side panel. Not sure If I'm going to look to something 3D printed or fab something up for them out of metal, metal tubing.
Old 03-31-2020, 04:28 PM   #34
Got the dual exhaust exits done. Well, close to done. Still some detail work to do.
Old 03-31-2020, 10:17 PM   #35
Better and better - awesome work!
durok is offline   Reply With Quote
Old 04-01-2020, 07:08 AM   #36
Thank you durok!
Old 04-01-2020, 09:52 AM   #37
Moderator
That would be awesome! I'd love to try some racing on my Grom.
The Dragon Slayer is looking good. The fabbed exhaust is great. That looks much better than anything 3D printed would have looked!
Old 04-01-2020, 11:08 AM   #38
Location: North to Alaska - go north, the rush is on....
Definitely looks AWESOME man, keep it up.
The exhaust tips look great!
AK KRAWLER is offline   Reply With Quote
Old 04-01-2020, 04:59 PM   #39
Well, you're not so far away that if we can get some buy in from the other guys, we'll get a little series going and I'll give u a heads up.
Old 04-01-2020, 04:59 PM   #40
Thanks AK - Appreciate it!
Project Dragon Slayer GOM - Similar Threads
Cambpell Racing Dragon Slayer nsimps Axial Yeti 79 04-05-2018 01:51 PM
EmeryworX yeti XL dragon slayer chassis tuner Axial Yeti XL 9 06-19-2017 12:28 PM
Project Red Dragon. kyle_l Axial Wraith 1 07-23-2011 10:09 PM
