GS02 Double Cab Suspension to stiff Just picked up a komodo double cab kit. I like it but the flex is left wanting. The included springs are way to stiff. I am wondering if the softer springs will really allow it to bottom out the shocks and let it flex. The problem is I am in Guam so I have to order these and wait two weeks for them to come in. So I want to make sure they will work. Or looking for other options that are reasonably priced. |
Re: GS02 Double Cab Suspension to stiff Quote:
If you use the Cage body from the original GS02 release, then you would need the cantilever or inward leaning shock setup. The cage doesn’t play well with the rear shock hoops. But to answer your question, I didn’t find the softer springs on the cantilever setup as satisfying as I’d hoped. |
Re: GS02 Double Cab Suspension to stiff The Komodo Double Cab has normal stand up shocks in the rear. Yes, the stock springs are way too stiff. I put Traxxas TRX4 springs on mine. White in the back and orange in the front. Originally tried white springs front and rear (same as on a stock TRX4 Sport) but the Komodo Double Cab is heavier up front so I went one spring weight higher in the front. Springs fit the Gmade shocks perfectly and REALLY allow the suspension to work. Highly recommend "thumbsup" |
Re: GS02 Double Cab Suspension to stiff I simply replaced them with the SSD Soft springs for 90mm shocks, work perfectly on the Gmade dampers. But when you place softer springs on, what I found is that my left/right weight balance was off as the motor and the relatively heavy Mamba X were tilting the car towards the left side. I had to swap the Mamba ESC to the right side which makes things way better. |
