11-30-2013, 01:02 PM | #1 |
Quarry Creeper Join Date: Jan 2012 Location: Newmarket, Canada
| JP's Sawback |
11-30-2013, 04:22 PM | #2 |
Newbie Join Date: Nov 2012 Location: Springville
| Re: JP's Sawback
I like it! |
12-02-2013, 07:12 AM | #3 |
Rock Stacker Join Date: Nov 2013 Location: Australia
| Re: JP's Sawback
two thumbs up, looking good mate.
12-02-2013, 01:30 PM | #4 |
| Re: JP's Sawback
Thanks guys, had some time to drive this rig now, and it's too much fun! Makes my entire rock course MUCH more challenging, can't wait to get it out on a trail run and see how it does against some SCX10's. I made this quick video yesterday: https://www.youtube.com/watch?v=jnxco7LoITc How do I Embed the video? |
12-03-2013, 01:35 PM | #5 |
| Re: JP's Sawback |
12-03-2013, 01:48 PM | #6 |
Quarry Creeper Join Date: Aug 2013 Location: Colorado Springs
| Re: JP's Sawback
JP your rig looks awesome bud! I really like the color you got on her. Great shots of it in action also...keep it up!
12-03-2013, 01:53 PM | #7 |
| Re: JP's Sawback
Any reason you put the front bumper on top of the frame rails?
12-03-2013, 02:00 PM | #8 |
| Re: JP's Sawback |
12-03-2013, 02:02 PM | #9 |
| Re: JP's Sawback |
12-08-2013, 05:01 PM | #10 |
| Re: JP's Sawback
SO, here's my thoughts on the kit after it's first real trail run (4hrs). The shocks froze up almost completely solid, this may have had to do with submerging them a bit. The rollers on the skids fill up with gunk and stop rolling pretty quickly, but I did finally actually see them work a couple times. I may remove them to gain an extra 1/8" skid clearance (every bit counts with this rig!). The transmission case is not 100% sealed with the included cover, but a layer of grease on the inside of the cap when installing should be more than enough to keep it mostly water/crap-free. The single-leaf setup that I'm running has worked in well, I will be adding a second leaf to the front suspension for sure, maybe hold off on the rears for now. The tires haven't changed much since out-of-the-box, but they are starting to wear a bit more than I thought they would have in this cold slippery weather. 35t motor and 11t pinion is just barely faster than walking pace, but provides about 3hrs runtime in the cold, which is great! I am still having a BLAST with this truck, it's just small enough to make everything a challenge, but it kept up to most of the rigs on the trail today. |
12-09-2013, 06:01 AM | #11 |
| Re: JP's Sawback
One of the stock Battery zip-ties broke on me today, it was very cold out and I didn't apply much pressure at all, and snap! Will be replacing with velcro soon
12-14-2013, 05:25 PM | #12 |
| Re: JP's Sawback |
12-14-2013, 06:08 PM | #13 |
| Re: JP's Sawback
Nice score on the driver! how tall is he?
12-14-2013, 06:13 PM | #14 |
| Re: JP's Sawback
About 7 5/8" tall measured from head to leg to knee to foot at each joint with cheap plastic calipers, so I got as close as I could. Didn't feel like un-strapping him! Fits the seats and steering wheel well! I had to trim away a lot of the knee and hip joint to get him to bend enough to fit, and he still hovers above the seat about 1/4"
12-19-2013, 06:43 PM | #15 |
RCC Addict Join Date: Feb 2012 Location: Ca.
| Re: JP's Sawback
The more I look at your bumper mounted on top the more I like it. I'm going to try mine up there.
12-29-2013, 09:28 AM | #16 |
| Re: JP's Sawback
Some updates. running the soft leaf setup didn't work out so well, and adding a second leaf on top didn't help either, this is the result after about 25 hours on this truck. You can see how the leaf deformed, this is the FRONT axle and they bent BEHIND the axle. I'm now running a medium leaf under the main Last edited by jp0160; 12-29-2013 at 10:29 AM. |
12-29-2013, 09:32 AM | #17 |
| Re: JP's Sawback
When you put the medium leaf under the main leaf and remounted to axle, did it straighten out your main leaf?
12-29-2013, 10:28 AM | #18 | |
| Re: JP's Sawback Quote:
I am having trouble deciding which setup I like better, medium leaf on top with zip-tie's behind the axle (softer, but may deform the front of the leafs), or medium underneath with no zip-ties (a little too hard for my liking) | |
12-29-2013, 10:50 AM | #19 |
| Re: JP's Sawback
I was hoping that after a few hours of run time the springs would soften some. I am running my small leaf on top of the main leaf with zip ties on the front and medium on top of main in the rear without zip ties.
12-29-2013, 11:39 AM | #20 |
| Re: JP's Sawback
the main leafs do soften a bit, but only so much. Taking off the stock shocks will give a little more up/down travel too, the shocks are a bit useless
JP's Sawback - Similar Threads | ||||
sawback or dingo? | crazy nick | General Crawlers | 14 | 01-02-2014 11:25 PM |
G-Made Sawback IN STOCK | RPP Hobby | RPP Hobby | 5 | 12-30-2013 04:40 PM |
The new gmade sawback is coming! | Reaxion911 | G-Made Sawback | 3 | 11-07-2013 02:23 PM |
JP's 01 jeep XJ | jprock | 1:1 Full Size Vehicles | 6 | 09-23-2013 09:35 PM |
