12-06-2013, 11:36 AM | #1 |
RCC Addict Join Date: Feb 2012 Location: Ca.
| Sawback Questions
Now that you've run your Sawbacks, I have a couple of questions just to see where you all are on a couple of things. Have you vented your Sawback wheels? Do you see the need? I haven't but I think I'm going too. Have you gone to a larger diameter tire? I've switched to the Trepadors. I may go back to stock when my new skid plate shows up. What turn motor and pinion tooth count are you using? I am using a 35T Tekin motor with a RR 15 tooth pinion. I am going to try a 12 tooth RR. I switched from the stock 12 tooth pinion because mine was very noisy. The RR quieted things down. Are you running 2s or 3s? I am running 3s. Did you glue in your windshield glass when you installed it or just slide it under the tabs? Mine is just under the tabs and not glued. Thanks guys. |
12-06-2013, 01:19 PM | #2 |
Quarry Creeper Join Date: Jan 2012 Location: Newmarket, Canada
| Re: Sawback Questions
Left my wheels sealed, I run in water a lot. Stock tires turned backwards grip well and tall enough 35t Integy motor with 11t pinion 2s No glue, it's a scale rig so I don't plan on rolling it much |
12-07-2013, 06:21 AM | #3 |
| Re: Sawback Questions |
12-07-2013, 09:19 AM | #4 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
I've seen a couple of videos of this rig, and so far all three videos showed a distinct lack of flexibility...especially in the front. The ride Looked stiff to me also. Anybody worked a little on the front shocks at all? Seemed that that was the issue, from the vids anyway. Considered buying one, but backed off when I saw this.
12-07-2013, 09:42 AM | #5 | |
| Re: Sawback Questions Quote:
12-08-2013, 05:33 PM | #6 |
Well that's good info Joe....I'm a sucker for a jeep
Sawback Questions - Similar Threads | ||||
Sawback | hotwheels000 | G-Made Sawback | 19 | 05-09-2015 05:32 PM |
Got a sawback today. | cguit | G-Made Sawback | 14 | 01-17-2015 04:03 PM |
JP's Sawback | jp0160 | G-Made Sawback | 48 | 03-23-2014 08:27 AM |
sawback or dingo? | crazy nick | General Crawlers | 14 | 01-02-2014 11:25 PM |
The new gmade sawback is coming! | Reaxion911 | G-Made Sawback | 3 | 11-07-2013 02:23 PM |
