12-22-2013, 04:34 PM | #1 |
Quarry Creeper Join Date: Oct 2013 Location: Nanaimo
| What have you broken on your sawback?
Hey all im going to throw together a trail first aid kit for my sawback and i was wondering what has broken on your guys rigs so i know what to order for partz! Thnx in advance
12-22-2013, 05:47 PM | #2 |
Quarry Creeper Join Date: Jan 2012 Location: Newmarket, Canada
| Re: What have you broken on your sawback?
Nothing! 25+ hours on my Sawback, did break a zip-tie due to the cold though
12-22-2013, 06:04 PM | #3 |
Seems to be the general consensus. Im yet to hear of anyone breaking parts
12-24-2013, 08:02 AM | #4 |
RCC Addict Join Date: Feb 2012 Location: Ca.
Nothing broken. My pinion gear teeth were cut strangely and it was very noisy. I replaced it with a RR 12 tooth pinion.
12-26-2013, 03:56 PM | #5 |
Well i went for an awesome group rin today and im happy to say the only issues i had was popped a front drivshaft apart which i was able to just put back together. I did not go easy on this truck at all with a titan 12turn on 3s. Aldo performed very well and had the lot impressed with its capablity
12-30-2013, 07:19 PM | #6 |
Rock Stacker Join Date: Nov 2013 Location: Australia
The only drama I have had was the pin came out of the rear tailshaft joint but I just hammered a nail in there and has been sweet ever since,
12-30-2013, 07:35 PM | #7 |
Rock Stacker Join Date: Dec 2011 Location: Gosport
I have wondered about the Sawback, glad to hear that you guys have had good luck with it.
12-30-2013, 09:30 PM | #8 |
My Junfac carbon steel drive shafts arrived today. They will be installed tomorrow.
01-02-2014, 07:09 AM | #9 |
Pin on one of the front dogbones wiggled out causing it to bind up bending the head of the dogbone. I then snapped it off trying to straighten it back. Used an old exceed axle i had in the parts bin. Had to cut it down a little but is in place running smooth again.
01-11-2014, 07:45 PM | #10 |
Broke a rear leaf right behind the mount on the axle. Used a pull cord spring and built a couple new ones as my lhs supplier cant get stock replacments yet
02-03-2014, 07:38 PM | #11 |
Rock Stacker Join Date: May 2008 Location: Taylors
Dog bone snapped off after 15 minutes of running it in the snow. Running a holmes hobbies 27 turn on 2 cells. Not real happy. Ordered upgraded cva's
02-04-2014, 12:01 AM | #12 |
| Re: What have you broken on your sawback? |
02-04-2014, 06:59 AM | #13 |
| Re: What have you broken on your sawback? When I pulled mine out to install the cva's, they showed a lot of wear for the few hours I had on my Sawback. Inferior metal and heat treat in my opinion.
02-18-2014, 08:50 AM | #14 |
Rock Stacker Join Date: Jan 2014 Location: Australia
I'm running the CVA setup, supposed to get a better turning circle but I don't know as I installed them from new.
02-18-2014, 05:48 PM | #15 |
Rock Crawler Join Date: May 2011 Location: at your moms
haven't broken anything yet, I put cvds in it before running it im fairly impressed with the SB capabilities so far
02-19-2014, 07:02 PM | #16 |
Pebble Pounder Join Date: Jan 2014 Location: SE Iowa
Did the pinion gear swap yesterday just as race18 had done earlier to help quiet down some of the transfer case chatter. So far just a bent leafspring & the pinion but haven't actually broken anything yet.
02-19-2014, 07:19 PM | #17 |
Pebble Pounder Join Date: Feb 2011 Location: Cookeville
I had the set screw on the driveshaft yoke back out, and the pin fell out. A new pin and some more loctite took care of the problem. Everything else is solid.
02-21-2014, 09:53 AM | #18 |
Pebble Pounder Join Date: Jun 2013 Location: Northridge,Ca
Its though!!!! I accidentally rammed my buddies scx10 and I ripped his body with my front bumper.. Sent from my iPhone using Tapatalk |
02-23-2014, 12:33 PM | #19 |
Newbie Join Date: Feb 2014 Location: Citrus Heights
Just a thought. Being as this is direct drive(no slipper) having a plastic drive line joint separate or drop a pin is actually quite nice. Upgrading to the cvds will remove this simple failure point and now the transmission/driveline/and diff are going to take the grunt of the torque. In my book, I'll repair driveshafts all day long opposed to replacing a ring and pinion or trans gears. Again, just a thought.
02-23-2014, 02:00 PM | #20 |
I may as well post an update, another 4 hours of hard trail running today and I still haven't broken a thing.. That brings me up to about 60 hours on this rig!
What have you broken on your sawback? - Similar Threads | ||||
My Sawback | 06ToasterBox | G-Made Sawback | 86 | 01-17-2020 01:27 PM |
Sawback | hotwheels000 | G-Made Sawback | 19 | 05-09-2015 05:32 PM |
Got a sawback today. | cguit | G-Made Sawback | 14 | 01-17-2015 04:03 PM |
JP's Sawback | jp0160 | G-Made Sawback | 48 | 03-23-2014 08:27 AM |
sawback rollcage? | stevem50 | G-Made Sawback | 22 | 12-28-2013 04:53 PM |
