02-06-2014, 01:48 PM | #61 |
| Re: Chiefs Sawback Build - Spring-Under Susp
Sweet looking Sawback!
02-13-2014, 10:35 AM | #62 |
Pebble Pounder Join Date: Feb 2011 Location: Cookeville
Thread update time. I decided to do a shackle flip on the truck. I only drilled one new hole on the chassis for the fixed hanger on the front of the frame. I was able to use existing holes for the rest. I should be done tonight, I'll get pics of the set-up and how it looks this afternoon. Next up, I will be moving the front axle forward for a better approach angle, and I'm thinking of dove-tailing the rear of the body. I'll get some pics up tonight. |
02-13-2014, 10:47 AM | #63 |
RCC Addict Join Date: Feb 2012 Location: Ca.
Looking forward to seeing your mods.
02-14-2014, 05:52 AM | #64 |
RCC Addict Join Date: Jun 2010 Location: Australia NSW
interested to see where this goes. im on the fence regarding getting one. id chuck an old hilux body on it tho i reckon. anyways, ill sit back with the popcorn and watch |
02-14-2014, 06:11 AM | #65 |
OK, I didn't get to finish it last night, but I'll get some pics up around lunch time. The frame is clearanced for the shackle mounts, and the mounts are bolted on. I'm gonna try and finish it tonight at some point. I know we all love pictures, so I"ll get them on here asap.
02-16-2014, 07:26 AM | #66 |
Updates Chief ????
02-17-2014, 10:00 AM | #67 |
I'll have pics up tonight for y'all. I took it for a test drive yesterday, and popped the frt. driveshaft three times in 5mins. LOL With the shackle flip, the driveshaft angle is too steep. Some electrical tape will get me through until I get the RC4WD shims this week. The fenders will need to be cut a little more, and there is no way to bolt the bumper back on. I'm going to braze it back on.
02-17-2014, 06:38 PM | #68 |
Here are some pics of the shackle reversal. The suspension articulates smoother, plus it has a little more travel/flex. I had to clearance the shackles some, and trim the fenders where the tires were flexing into it. This shows how much I ground off for the shackle mount. Here are the front fixed mounts. I plan on moving the front axle forward to get the tires even with the front of the frame. I plan on using the RC4WD shims to get the angles good. I'm also looking into diff. leaf springs that have offset holes already drilled. Here is the approach angle with the shackle reversal. |
02-17-2014, 06:41 PM | #69 |
I plan on cleaning up all my cuts on the body, maybe dove-tail the rear, and definitely make some floorpans to support the roll-cage. Also need to re-solder one of the tubes and braze the front bumper. I have more pics if anyone wants to see it.
02-17-2014, 06:59 PM | #70 |
Newbie Join Date: Feb 2014 Location: Singapore
that's brilliant! yes more pics please!
02-18-2014, 06:50 PM | #71 |
Here is the link to the photobucket account for more sawback pics. There are some pics of my WJ also. Library Slideshow by Riby1979 | Photobucket |
02-19-2014, 06:28 PM | #72 |
| Re: Chiefs Sawback Build - Spring-Under Susp |
02-21-2014, 10:15 AM | #73 |
Rock Stacker Join Date: Jan 2014 Location: Australia
look forward to seeing how well this rig crawls after all the mods.
02-21-2014, 11:40 AM | #74 |
Hopefully I can get some video of it soon. I usually go crawling alone unless there's a crawl scheduled. I'll have to video it myself somehow. LOL
02-26-2014, 07:59 AM | #75 |
Well, I've finally got an update. The dovetail is done. I finally cut down and mounted the shocks. The truck is performing great, and I love the looks of the dovetail. Here are some pics. Next step is to re-do the cage, and add some sliders and a rear bumper. The cage will be lower, and the front bars will be laid back slightly more. |
03-28-2014, 09:31 AM | #76 |
Finally have an update. I made some floor pans to sandwich the lexan floors that were tearing. This also gave me a solid point to mount the front bars of the cage. I also made some front inner-fenders, cleaned up the wiring, re-trimmed the front fenders, and made a center console to cover the hole I had left from all the cutting. I used black styrene for everything. Real happy with the outcome, the truck looks cleaner to me. |
03-28-2014, 09:34 AM | #77 |
03-28-2014, 03:45 PM | #78 |
Quarry Creeper Join Date: Mar 2013 Location: Pilipinas
I love what you did to the rear fenders. Awesome job! Sent from my iPad using Tapatalk HD |
03-28-2014, 07:56 PM | #79 |
Thanks Dextan. I wanted to create my idea for a crawling/trailing willys, and I'm about there. Hopefully sunday I can get some video of the rig.
03-31-2014, 12:47 PM | #80 |
Rock Crawler Join Date: Feb 2013 Location: Casper
Looks great!!!! Sent from my SAMSUNG-SM-N900A using Tapatalk |
Chiefs Sawback Build - Spring-Under Susp - Similar Threads | ||||
Crawlorado719 GMade Sawback Build | Crawlorado719 | G-Made Sawback | 162 | 04-01-2014 10:08 PM |
twilights sawback build, back to scalers | twilight | G-Made Sawback | 10 | 01-24-2014 05:30 PM |
Wild Willy On A Sawback [Sawback Solo Run] | ifulg | G-Made Sawback | 1 | 12-24-2013 08:06 PM |
Chiefs JK Buggy | Chief | 2.2 Scale Rigs | 9 | 03-15-2012 06:58 AM |
