12-15-2015, 10:40 PM | #1 |
Rock Crawler Join Date: Aug 2011 Location: SB
| Just ordered my sawback
Well I finally ordered a sawback, I have been wanting on for sometime now, so I went for it, crabbed some goodies to go with the build |
12-16-2015, 01:10 AM | #2 |
Pebble Pounder Join Date: Mar 2014 Location: Lenoir, NC
| Re: Just ordered my sawback
I highly recommend the Metal Spacers for GS01 Leaf Spring Kit - GM52135S. Hope you have as much fun building yours as I am building mine! Sent from my VS985 4G using Tapatalk |
12-16-2015, 02:07 PM | #3 |
| Re: Just ordered my sawback O ya , the Leaf Spring Perch's aswell. Few other things including tires, wheels and CI foam knk hardwear brass axle weights, and some aluminum bits |
12-17-2015, 07:48 AM | #4 |
The stainless steel screw kit is a good call. Not sure what you mean by leaf spring perches. The Sawback is so awesome. It doesn't get the credit it deserves. The truck is friggin' tough and it will crawl over many things and it will surprise the heck out of you and others around you. One suggestion, keep a set of leafs on hand. They do bend. |
12-17-2015, 09:10 AM | #5 | |
| Re: Just ordered my sawback Quote:
MY bad these are stock parts Last edited by desertdude; 12-17-2015 at 04:01 PM. | |
12-17-2015, 12:51 PM | #6 |
I Have a set of king scale 90mm lying around, going to run them just ordered the spring kit so I can run the soft springs. My buddy runs them with 20wt and use's 2 leafs the long one's and the 2nd longest really nice flex but I might use the 3rd spring, will see. How are some of you guys running your springs? Last edited by desertdude; 12-17-2015 at 01:21 PM. |
Just ordered my sawback - Similar Threads | ||||
Sawback vs. Sawback Sports | scaled | G-Made Sawback | 6 | 04-01-2015 09:04 PM |
Kit Ordered, Parts Ordered, Suggestions??? | OkinawaCrawler | Tamiya XC/CC01 | 6 | 02-21-2014 09:52 AM |
Wild Willy On A Sawback [Sawback Solo Run] | ifulg | G-Made Sawback | 1 | 12-24-2013 08:06 PM |
Just ordered!!! 1 | zdaddy | RC4WD Bully | 10 | 03-13-2010 06:46 PM |
just ordered a WK!! | bigmike07 | Chit Chat | 8 | 09-01-2007 09:45 AM |
