06-12-2016, 02:32 PM | #1 |
Pebble Pounder Join Date: Jan 2016 Location: Port Huron
| Gmade CVA
So I have encountered a problem. Maybe you can help as I don't have a ton of experience in RCs yet. I am building a sawback. I put the CVA kit up front. I also flipped the chubs and zero ackerman knuckles. The steering is great. I can make my tire hit the leaves, but I cannot run that much steering. When I am trailing and corner at any small speed, I get wheel hop like crazy. I am thinking I am binding the CVA. Has anyone else experienced this? Are there other CVAs that have more clearance thatl'll fit? |
06-12-2016, 02:35 PM | #2 |
Rock Stacker Join Date: Oct 2010 Location: Boonies of CT
| Re: Gmade CVA
I am having this problem now also. Working on a fix now.... I have snapped a few now. There binding at full turn. I also have a 500oz servo. Lol https://www.facebook.com/events/1692165367732269 |
06-12-2016, 06:32 PM | #3 |
| Re: Gmade CVA
I wanna say I saw a thread when someone used trex cvds. But i believe that was before gmade came out with everything and they used different knuckles.
06-12-2016, 06:38 PM | #4 |
| Re: Gmade CVA |
06-12-2016, 06:40 PM | #5 |
| Re: Gmade CVA
I have the same issue. It started as soon as I put the aluminum knuckles on https://www.facebook.com/events/1692165367732269 |
06-13-2016, 09:34 AM | #6 |
| Re: Gmade CVA
I saw GCM has a cva on eBay. Anyone try it?
06-13-2016, 12:42 PM | #7 |
Quarry Creeper Join Date: Feb 2015 Location: Amongst the UTards
| Re: Gmade CVA
Have pics of the setup?
06-13-2016, 02:00 PM | #8 |
| Re: Gmade CVA Just the normal set up. From what I read the Cva just suck. I might buy the gpm version. $20. Might be worth it. Sent from my iPhone using Tapatalk |
06-15-2016, 12:47 PM | #9 |
| Re: Gmade CVA
I ordered the gpm ones. Gotta wait for shipping but hopefully it fixes this problem. I'll update when I get them. Sent from my iPhone using Tapatalk |
06-15-2016, 09:29 PM | #10 |
Rock Crawler Join Date: Dec 2014 Location: In the sticks
| Re: Gmade CVA
I've got 4 sets of these running around with modified knuckles and c-hubs. Haven't had a single issue. I must be doing something wrong?
06-16-2016, 04:13 AM | #11 |
| Re: Gmade CVA
I'm assuming the other way around and I'm doing something wrong. Are you running the zero Ackerman knuckles or just cut original ones? It might be the knuckles. Sent from my iPhone using Tapatalk |
06-16-2016, 05:32 AM | #12 |
| Re: Gmade CVA I have modified stock plastic knuckles, modified aluminum and zero ackerman knuckles, all with the same amount of steering. Only thing I can think of is make sure you keep them clean and greased.
06-16-2016, 05:39 AM | #13 | |
| Re: Gmade CVA Quote:
I have only driven in my house or on the sidewalk. No trails or comps yet. This Saturday is the first with it. I used all of the supplied grease to assemble. How sharp is your turning set? If I reduce the throw on my radio it'll run but the steering isn't great. Sent from my iPhone using Tapatalk | |
06-16-2016, 08:40 PM | #14 |
| Re: Gmade CVA
These tires will actually hit the springs at full turn. Had to drop back down to Ripsaw's for clearance. It will wheel hop slightly when steering is at full throw while running at full throttle. Mostly when running around in the house. Never notice it when I'm actually out crawling. I'm running 3 crawlers with GS01 axles and one with R1 portals. All have been reworked to gain the maximum amount of steering. Haven't had a bit of trouble out of any of them yet, but I run 27T-35T brushed motors on 2s. No excessive power or crazy speeds.
07-10-2016, 04:20 PM | #15 |
| Re: Gmade CVA |
07-10-2016, 04:21 PM | #16 |
| Re: Gmade CVA
I've been beating my gmade ones hoping they will break. No luck. I'll swap the other ones in and see if they bind for you though. Give me a couple hours. Sent from my iPhone using Tapatalk |
07-10-2016, 04:36 PM | #17 |
| Re: Gmade CVA
Do they appear any different in construction.
07-10-2016, 09:41 PM | #18 |
| Re: Gmade CVA
I'm still at a loss as how people have problems with the Gmade cv's? I beat the snot outta the 4LS yesterday at a timed hill climb, and after several runs up the hill at full speed and several long tumbles back down without any troubles at all with cv's or any other part for that matter. I do have a secret that I've tried to share with people for 20 years now, but nobody has yet to listen. I use VersaChem caliper grease on everything. Grease the diffs, tranny and cv's with it. It sticky, so it stays where you put it for the most part, and after a year on my original Sawback the diff gears have no wear at all. I also keep a close eye on all CV joints in all of my rigs. Keep them clean and greased! This grease will make a stock Sawback shock dampen like an oil shock too. Last edited by Jeepiac; 07-10-2016 at 09:54 PM. |
07-11-2016, 01:22 PM | #19 | |
07-11-2016, 08:15 PM | #20 | |
Gmade CVA - Similar Threads | ||||
cva vs universals | nothinbutv8s | Newbie General | 3 | 07-30-2009 06:37 AM |
Axial AX10 Scorpion CVA Driveshafts | t9dragon | Axial AX-10 Scorpion | 33 | 01-19-2008 02:09 AM |
