08-25-2016, 11:11 AM | #1 |
Newbie Join Date: Apr 2016 Location: Belgium
| Mr. Ed's Sawback 4LS "No rules applied"
Here's my 4 link Sawback as it stands now. It's pretty much new but got some heavy personal seasoning, awaiting better weather at first, and new rear shafts after its maiden run. A quick run-through: Added weight in wheels, new foams in the tires, 14mm wheel wideners, red alu lock-outs, C hubs and steering knuckles, homemade battery mounts to put the saddle pack cells on the front and rear axles rather than on the chassis, reversed and moved forward center gearbox, shortened front center shaft. flipped axles, homemade esc mount, homemade rear shock mounts, tucked in bumper, trimmed chassis rails, raised steering links, relocated suspension links, Kimbrough servo saver, GPM rear shafts. These last 2 were added after my first time out. The car tipped sideways and bounced down a long steep hill. The rear shaft got bent badly and savox low profile servo lost some teeth. |
08-25-2016, 11:23 AM | #2 |
| Re: Mr. Ed's Sawback 4LS "No rules applied"
I had Pamela Anderson in mind, with a little red bikini... but a machine gun mount is sadly enough easier to find.
08-25-2016, 12:26 PM | #3 |
Quarry Creeper Join Date: May 2010 Location: ny
I like this Sent from my iPhone using Tapatalk |
08-26-2016, 07:11 PM | #4 |
Actually, ebay has some 7 inch Pamela Anderson dolls
08-28-2016, 04:23 AM | #5 |
I found this barbie doll on a flea market just around the corner. She costed me only 2 euros. I cut her legs and bent and shortened her neck. Now i just need to figure out how to keep her in place. Last edited by Mr_Ed; 08-28-2016 at 04:35 AM. |
08-28-2016, 08:39 AM | #6 |
| Re: Mr. Ed's Sawback 4LS "No rules applied" |
08-28-2016, 12:53 PM | #7 |
What aiden said, or make a seatbelt/shoulder harness out of a shoelace to hold her in place.
08-28-2016, 01:41 PM | #8 |
08-31-2016, 12:16 PM | #9 |
08-31-2016, 01:40 PM | #10 |
Rock Stacker Join Date: Aug 2016 Location: Northern AZ
If you get one of the larger dolls, I believe they have predrilled holes. |
10-08-2016, 12:09 PM | #11 |
Quarry Creeper Join Date: Oct 2013 Location: Nanaimo
Can u please explain your reasoning on flipping the axles? Sent from my iPhone using Tapatalk |
10-11-2016, 12:29 PM | #12 | |
| Re: Mr. Ed's Sawback 4LS "No rules applied" Quote:
when I first ran the car I felt like it had lots of torque twist. And I had read about other cars where people were flipping the center gearbox to counter this. At the time I wasn't ready to flip the gearbox... Yet. So I filipped the front axle, and rear axle. (Meaning the top of the axle becomes the bottom side.) And then reversed the motor rotation sense. Since then I've had the gearbox flipped, axles turned over again, gearbox turned back again and moved an inch forward, moved, and moved back again. I just like tinkering I guess Right now I'm finalizing the car to match some chop-chop body mods I did: | |
10-11-2016, 12:38 PM | #13 |
| Re: Mr. Ed's Sawback 4LS "No rules applied" I slislightly over trimmed the front wanting to take out the old body post holes. But the ultra short front bonnet reminds me of the old wild-willy, so it's no disaster and there's no way back anyway . |
Mr. Ed's Sawback 4LS "No rules applied" - Similar Threads | ||||
Sawback 4LS | Jeepiac | G-Made Sawback | 5 | 04-25-2016 07:14 PM |
New Sawback 4LS Kit | JohnB | G-Made Sawback | 6 | 02-26-2016 01:49 PM |
KB7ZPJ's Sawback "Round Toit" Build Thread | k7zpj | G-Made Sawback | 1 | 12-23-2014 09:02 AM |
"Steady-cam" Gimbal Rig on Sawback Test | Shape_Shifter | Videos! | 22 | 06-12-2014 08:28 PM |
