10-10-2017, 01:05 PM | #41 |
| Re: Just ordered a Sawback!
Sweet! They look good.
10-10-2017, 03:03 PM | #42 | |
Quarry Creeper Join Date: May 2017 Location: Bellevue
| Re: Just ordered a Sawback! Quote:
Cool front bumper but a pain to install. You have to take the leaf spring shackles off and hope you have a small enough set of needle nose to hold the nut on the under side. Sent from my iPhone using Tapatalk | |
10-10-2017, 05:33 PM | #43 | |
Newbie Join Date: Nov 2012 Location: Winnipeg
I had mine mounted on the chassis without a panhard..hated it..went with servo on axle..never looked back..you can’t really see it up there either which is nice! Sent from my iPhone using Tapatalk | |
10-11-2017, 01:11 PM | #44 |
| Re: Just ordered a Sawback! |
10-11-2017, 02:51 PM | #45 |
Well my upgrade parts showed up so I can continue the build. There they are in my front porch as I'm stuck at work. Sent from my iPhone using Tapatalk |
10-11-2017, 08:36 PM | #46 |
Could use some assistance here. So I've got Zero Ackerman Knuckles and steering rods. Do I need to mount the servo on the chassis to use this setup? Because as you can see the steering rod is sitting on the leaf spring and hasn't even made it down to the mounting hole on the servo horn. I'm using what I think is a pretty standard length servo horn at about 24mm. Sent from my iPhone using Tapatalk |
10-11-2017, 09:36 PM | #47 |
Looks like you need a 5mm spacer on top of the knuckle. Both of mine are under the spring, though I'm using the standard knuckles.
10-11-2017, 09:38 PM | #48 |
Gotcha. I think I'm going to just do a CMS. Sent from my iPhone using Tapatalk |
10-11-2017, 10:37 PM | #49 |
Some of the upgrades I I went with. Sent from my iPhone using Tapatalk |
10-12-2017, 07:49 AM | #50 |
10-12-2017, 04:25 PM | #51 | |
| Re: Just ordered a Sawback! Quote: Ah I see you installed the steering link on top of the knuckles and put the pan hard link on top of that. Got it. Sent from my iPhone using Tapatalk | |
10-12-2017, 04:30 PM | #52 |
Got the axles mounted and electronics installed. Sent from my iPhone using Tapatalk |
10-12-2017, 04:38 PM | #53 |
10-13-2017, 02:58 PM | #54 |
Well that's it, build complete. Just working on the body now. Went with the "soft" leaf spring setup. Not sure if I'm digging how the middle spring sits on top of the main spring. Thinking of swapping them kinda like the TF2 leaf spring setup. But I want as much flex as I can get as I will mainly be crawling it. Swapping the leaf springs a viable option or no? Sent from my iPhone using Tapatalk |
10-13-2017, 03:42 PM | #55 |
Lol, I just realized you went brushless on this rig. Quite a bit of power for it. I just stuck a Hobbywing 1060 + 27T and called it a day. LOL |
10-13-2017, 07:57 PM | #56 |
What's the benefit of running a short spring on top of the main leaf? I have mine set up like a conventional leaf with the helpers under the main and it flexes great. I see that a lot and I'm not clear what kind of benefit it provides.
10-13-2017, 07:59 PM | #57 | |
So in what order do you have your springs in? Sent from my iPhone using Tapatalk | |
10-13-2017, 09:40 PM | #58 | |
I did in hopes it would allow me to have soft springs while preventing some axle wrap. It did not. | |
10-13-2017, 10:16 PM | #59 |
The only benefit of a leaf above the main that I can think of is to prevent the main from bending around the u-bolt plate during droop/ forced articulation. Unless you run a military wrap (full length secondary spring that wraps around the eyelets of the main) I'd keep it there. If you want it to help reduce axle wrap, you might be better served to band the top leaf to the rest of the pack in front of the axle, a zip tie would probably work.
10-14-2017, 11:23 AM | #60 | |
Right that what the manual says. So I followed it and ya it doesn't make a lot of sense to me. Sent from my iPhone using Tapatalk | |
Just ordered a Sawback! - Similar Threads | ||||
Things to upgrade/watch out for Sawback 4LS & Sawback Sport | soze | G-Made Sawback | 2 | 02-28-2017 12:46 AM |
Just ordered my sawback | desertdude | G-Made Sawback | 5 | 12-17-2015 12:51 PM |
Sawback vs. Sawback Sports | scaled | G-Made Sawback | 6 | 04-01-2015 09:04 PM |
Kit Ordered, Parts Ordered, Suggestions??? | OkinawaCrawler | Tamiya XC/CC01 | 6 | 02-21-2014 09:52 AM |
Wild Willy On A Sawback [Sawback Solo Run] | ifulg | G-Made Sawback | 1 | 12-24-2013 08:06 PM |
