New Sawback I just purchased on Saturday the Sawback Jeep. Pretty cool rig. I installed a set of 1.9 BFG All terrain tires and rims from my Axial scx10-2 Cherokee. The added ground clearance is nice to have. What other mods work on these? Will some of the RC4WD 90mm shocks fit? Will the RC4WD teraFlex revolver shackles fit? It crawls pretty good for what it is. I think an oil filled shock will work better than a spring loaded shock. Sent from my iPhone using Tapatalk |
Re: New Sawback Quote:
Sent from my SM-G950U using Tapatalk |
Re: New Sawback You might want to look into the following for better steering and some weight. The anti-wrap kit is for preserving the leaf springs. GMADE Anti-Wrap Kit Boom Racing Servo Mount Zero Ackerman knuckles Bent Steering rod for Zero Ackerman Knuckles Aluminum C-Hub CVD Axles Brass Axle Tubes There are also rear lockouts and rock sliders which I did, but those aren't as big of a deal. |
Great question regarding the revolver shackles. I’m hoping somebody replies about that. Sent from my iPhone using Tapatalk |
I can understand the removal of the leaf spring and inner shock spring for more flex. I’m not sure about the axle flip. Mine is spring over. In the real 4x4 world we do spring over not spring under. Sent from my iPhone using Tapatalk |
