03-17-2008, 09:03 AM | #1 |
Quarry Creeper Join Date: Mar 2005 Location: hudson (the big city)
| strange sound from esc or drivetrain???
not sure if i'm in the right topic thread but i have a few questions. i just put together a bender sw2 with locked pede tranny, ax10 axles, ax10 spur and pinion, hh crawlmaster sport brushless, cc sidewinder. i'm getting a really high pitch squeal sound from either the drivetrain or esc, i'm not sure which, when i barely give it throttle from a stand still. is this a common thing? is there something wrong with my set up? any help would really be appreciated. thank you...
03-17-2008, 09:09 AM | #2 |
That is most likely the noise that the motor makes when being driven by a Castle ESC. They emit a high pitch beep which changes as the throttle changes.
03-17-2008, 09:17 AM | #3 |
RCC Addict Join Date: Jun 2007 Location: San Antonio, Tx
could be a bad mesh on your gears
03-17-2008, 09:21 AM | #4 |
I wanna be Dave Join Date: Nov 2005 Location: Crawler practice!
03-17-2008, 09:35 AM | #5 |
yeah, my gear mesh is okay. has a slight bit of play to it. so that end is covered. so it's probably nothing to worry about? if i just touch the throttle slightly where it's not enough to move the truck it will make the sound.
03-17-2008, 09:45 AM | #6 | |
brushless makes a lot of noise its just the motor and esc communicating with you Nothing to worry about! | |
03-17-2008, 09:49 AM | #7 |
thank you guys for the help. puts my worried mind to rest. thanks again...
03-17-2008, 04:25 PM | #8 | |
Quarry Creeper Join Date: Jun 2007 Location: Sacramento
why do they make that noise, is it a physics thing or does Castle design them to make that noise on purpose? | |
03-17-2008, 07:38 PM | #9 | |
some motors are real quiet like the original revolver on the mamba max that was a quiet set up | |
03-17-2008, 08:15 PM | #10 |
The motor is a speaker, the ESC is the amplifier that tells it what to do. The startup of Castle's firmware uses audible frequencies to keep the motor in sync with the ESC, and is a major part of the startup routine.
03-17-2008, 08:37 PM | #11 |
Quarry Creeper Join Date: Jan 2007 Location: I live in my own world,they know me here
The first time I heard my Hyperion/Max combo it made some noises I thought were bad and it turns out its a brushless thing.Creepy for sure but I got used to it
03-19-2008, 12:57 AM | #12 |
Pebble Pounder Join Date: Dec 2007 Location: Torrance
That noise is enough to keep the dogs away from us when we're crawling at the park!
