Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: Gear ratio difference between RC4WD R2 and 2speed?
Old 03-24-2008, 06:29 PM   #1
greasypete's Avatar
Default Gear ratio difference between RC4WD R2 and 2speed?
Hi,
my scale tuber has a R2 tranny with a 55turns motor. It crawls perfect, real slow (with axial axles and 2,2" tires).
I am thinking of adding some speed with a second gear.
My question: Is the R2 two speed gear ratio in first gear the same like the singlespeed R2, plus a slightly faster 2nd gear ? I am not sure about that ...
They say on their website:
Two speed: 6.7:1 (with 8 tooth pinion gear) or 11.4:1 (with 8 tooth pinion gear)
One speed:10:1 to 30:1 Gear Ratio (8T to 20T 32 pitch pinion gears)
It looks like the gears are completly different on the two speed version, or am I wrong?
Thanks for any help with that, bevore I buy something !
Pete
greasypete is offline   Reply With Quote
Old 03-24-2008, 07:13 PM   #2
Team Y-Town
4xFord's Avatar
Could you run different pinions to get the same first gear ratio that you have now on the 2 speed?
4xFord is online now   Reply With Quote
Old 03-25-2008, 06:34 AM   #3
greasypete's Avatar
I got answer from RC4WD (thanks!):
Its different, the gear ration in 1st is much faster. A smaler pinion wount help, because I already have a very small one.
Pete
