Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: r2d problem
Old 03-26-2008, 07:18 PM   #1
Default r2d problem
well today i took my tuck up to red rocks and my scroos on the disconect part kept comeing out so i tried to tighten them and one of them stripped and i lost one of the other screws
i dont know why but they just kept backing themselvs out of the threads
any thoughts on what to do
bigdog5332 is offline   Reply With Quote
Old 03-26-2008, 07:29 PM   #2
Damn-I need a chump RT!!!
yotachump's Avatar
go buy new screws from a hardware store, and put lock tight on the screws before you install them.
yotachump is offline   Reply With Quote
Old 03-26-2008, 07:31 PM   #3
Junk it!
F250 is offline   Reply With Quote
Old 03-26-2008, 07:34 PM   #4
yotachump's Avatar
Originally Posted by F250 View Post
Junk it!
X2, send it my way, I will dispose of it properly
Old 03-26-2008, 07:36 PM   #5
No don't junk it. There is a thread out there that shows how to fix this problem with slightly longer screws and thin jamb nuts on the inside of the tranny case. it's an easy fix, ya just gotta split the trans wide open.
A good time to lube the gears at the same time.
Mr. Burpsalot is offline   Reply With Quote
Old 03-26-2008, 07:37 PM   #6
i am not about to junk a $100 tranny with 2 hours on it
Old 03-26-2008, 07:43 PM   #7
Well if you do junk it I will give you my address!
Old 03-27-2008, 08:53 AM   #8
Scattman's Avatar
I had to do that on one of the screws holding my dig together. It has to be a really thin nut to work w/o roubbing the gears inside the tranny. I used one of the thin M3 nuts that come on TLT axles and still had to thin it down a hair. Works flawless now, especially with the Rocksmith teflon bushings in it.
Scattman is offline   Reply With Quote
Old 03-27-2008, 09:16 AM   #9
On the lookout for Rocks
constantmotion's Avatar
One of mine screws was stripped outta the package. I just replaced all there screws. I just inserted a button head M3 bolt from inside the case to the out and put and locknut on the outside....don't have any clearance issues.
constantmotion is offline   Reply With Quote
Old 03-28-2008, 12:12 AM   #10
i have had to repair 2 of my r2d trans for that problem, the treads pull out of the case. i countersank the holes from the inside and put lock nuts on the outside. problem repaired. the countersunk screws i think are 3mm by 28 or 30mm
jackal 69 is offline   Reply With Quote
Old 03-28-2008, 04:47 AM   #11
+1 ... I had the same problem, and I also made of lock tight
SwissSteph is offline   Reply With Quote
Old 03-28-2008, 08:48 AM   #12
offlander1's Avatar
damn how many people are having this issue?
all 3 screws that hold dig stripped out on mine while testing the dig. tried using 3mm nuts(ground very thin) but still get clearence issues with large gear inside tranny. contacted rc4wd they want $35 for new back plate. I DON"T THINK SO. will have to wait for my VF dig to come in and use that.
offlander1 is offline   Reply With Quote
Old 03-28-2008, 08:57 AM   #13
Hummm business is business !
VF Dig thinking is probably better and stronger
Old 03-28-2008, 09:09 AM   #14
littleskull99's Avatar
anybodys R2D noisy?
Mine seems louder going in the fwd direction than reverse, reverse is smooth and quiet.
I have checked the mesh and alls well.
I keep gettin told off by next door for goin out in the middle of the night to test the latest setup and makin load of noise!
Matt
littleskull99 is offline   Reply With Quote
Old 03-28-2008, 10:01 AM   #15
Originally Posted by littleskull99 View Post
anybodys R2D noisy?
Not yet ... But it is completely new and used very little for the moment
Old 03-28-2008, 10:56 AM   #16
Sonoma County Scalers
sloyota's Avatar
I had the same problem with R2D screws stripping.I just used traxxas 40mm screws and used them on the inside of the tranny with a little grinding of the heads to clear the gears,cut the screw to fit,and used nylock nuts with locktite.problem solved.now all of my friends are following in my foot steps.
I even got rid of stupid clear plastic dust cover and cut one out of steel and made it look just like the plastic one to mount my servo..Nothing flexes at all..now my little secret is out to the world..
Hope this helps out my fellow rc rockcrawlers...
I still love my R2D transmisson and would'nt change it for some thing different....
sloyota is offline   Reply With Quote
Old 03-28-2008, 11:15 AM   #17
crawlinghulls's Avatar
Came home after a day of crawling and noticed I was missing two of the three screws. threadlock did the trick.. now its time for the teflon bushings!
crawlinghulls is offline   Reply With Quote
Old 03-28-2008, 11:25 AM   #18
offlander1's Avatar
It's not good business if there appears to be a defective product, I say make it right. I brought a diablo chassis to use with my r2d, then had to buy a new punisher shaft because one side I need a longer shaft. spending all this money only to find out 1 part is now totally useless. making my current setup obsolete. tried to mount axail tranny to diablo chassis but won't fit. Guess I'll just have to chalk this up as a huge loss and move on.
can't wait for my VF dig (at least they go out of there way for Q.C.)
Old 03-28-2008, 11:28 AM   #19
Thats what it's for
Blood_Clod is offline   Reply With Quote
