Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: rsd and wheel speed
Old 03-27-2008, 12:00 PM   #1
I joined the Band!
Default rsd and wheel speed
ok
i have an r2d with a novak 55t and a 12t pinon
running axial axles
i would like a little more wheel speed without loosing
tork. (low end)
bought a 45t to try out, but dont know what pinon to use
leave the 12tooth or go down to 11tooth
or the 8 tooth that the r2 came with(most likely too low)
oh i run 6 cell 4500
maybe leave it and go to a 7th cell????????
im soooo confused......
thanx
nuts5000 is offline   Reply With Quote
Old 03-27-2008, 08:59 PM   #2
Go with the 45 with the same pinion that will give you a good starting point. I personally run a R2 tranny as well I run a 14t pinion, castle sidewinder, 55t, AND 11.1 3s Lipo's. Wheel speed is good and torque can be to much some times. But I like it and don't plan on changing it. Best thing to do is EXPERIMENT your style of crawling will not be the same as the next.
bulfrog is offline   Reply With Quote
Old 03-27-2008, 09:53 PM   #3
go with the 55t and get a 3cell lipo
Kranberry is offline   Reply With Quote
Old 03-27-2008, 10:27 PM   #4
Adding more cells will help get you some more wheel speed... I would try out the 45t with the 12 tooth pinion. If that turns out to be too little torque, you can always re-gear. Another option is to add a cell, put in the 45t, and drop down to the 8 tooth. That should be good.
Cake Eater is offline   Reply With Quote
Old 03-27-2008, 11:31 PM   #5
Scattman's Avatar
I am running an 8 tooth pinion, 35 turn Axiom, and 3 cell lipo. Good stuff.
Scattman is offline   Reply With Quote
Old 03-28-2008, 12:41 AM   #6
I joined the Band!
well
i put in the 45t motor and droped down 1 tooth to an 11t pinion
wheel speed seems better
just hope i didnt loose any tork
if it did i will go to a 10t pinion
Old 04-07-2008, 01:16 PM   #7
I joined the Band!
well it lost a lot of tork
went back to the 55t motor- 10tooth pinnon- 7cell
we will see how that is...............
Old 04-07-2008, 07:43 PM   #8
Just change one thing at a time. Document it. Keep on changing it till you get what you want.
Higher Turn - More Torqure/less wheel speed
Higher Voltage - More torque/more wheel speed
Smaller Pinion/Larger Spur - More torque/Less wheel speed
I'm sure you already know that but for anyone who doesn't. There ya go.
canadian_wk is offline   Reply With Quote
