Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: I want to know how R2 shifts
Old 03-28-2008, 04:47 AM   #1
Default I want to know how R2 shifts
Hei guy, I want to put together a rig that has 2 gears. I wonder if the R2 from RC4WD can shift while the truck is running. Also, will I have reverse.
E-maxx's 2 speed sounds good too, but won't you break the gears shifts when running. Does it have a "synco" like a real car?
Anyway tried the savage's 3 speed?
Thanks.
jayliu1984 is offline   Reply With Quote
Old 03-28-2008, 07:45 AM   #2
On the lookout for Rocks
constantmotion's Avatar
You can shift the R2D at any speed and yes, you will still have reverse.
constantmotion is offline   Reply With Quote
Old 03-28-2008, 07:24 PM   #3
he's talking about the r2 2 speed not the r2 disconnect
some_guy is offline   Reply With Quote
Old 03-28-2008, 07:57 PM   #4
you CAN shift the R2 speed while moving... I would not recommend it though.
yes you still have full reverse.
no clue about the other trans...
p!nK
mrpink is offline   Reply With Quote
Old 03-28-2008, 10:43 PM   #5
The e-maxx tranny was designed to shift at speed, all you have to do is shift, let off the gas and then get back on it. Poof, second gear!
FYI, stay away from the three speed, it is an atomatic, not the best for slower cars.
mysharona is offline   Reply With Quote
Old 03-28-2008, 10:56 PM   #6
you dont need to get off the gas to shift the emaxx...it shifts just fine at full speed without damage...mine survived for a while that way (trans is still find but i dismantled the truck)
nj05nismo is offline   Reply With Quote
