Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: tightest turning circle
Old 03-31-2008, 04:57 AM   #1
Default tightest turning circle
i'm rebuilding my super crawler
and have started looking into steering set ups
the thing is i have almost no knowledge of what works, i've see pictures of i think raptorman57's twin force with the wheels turning almost 90*
it doesn't matter what type of car they came from as long as they will hold up to my 40 series wheels and hard crawling
i'll be using hitec 805bb servo's to turn and later on when i get some time a rack and pinion steering setup to produce over 1000 oz/in of torque
i'm not scared of custom building stuff, because i've got about 130mm of diff clearance with clod diff centres, i've got no idea what that is in inchs because down here in aussie land we don't use it
some_guy is offline   Reply With Quote
Old 04-01-2008, 02:43 PM   #2
Southern buggy whore
ecoli's Avatar
I don't think the Twin Force axles are available any more, are they? No matter, to get a tighter turning radius, go with CVDs on whatever axle set-up you use. If you want to basically spin on a dime, I'd recommend something like clod axles with separate esc's for each axle and something like a DX6 to control it. That way, you can turn the front and throttle it forwards, and turn the rear and throttle it backwards. Would take some experimenting, but otherwise it should have an extremely tight turning radius (wheelbase of the truck).
ecoli is offline   Reply With Quote
Old 04-01-2008, 06:06 PM   #3
ecoli thats what i've done so far
i'm using maxx cvd's at the moment and want to turn alot sharper because it is only a slight improvement over clod dogbones
i'm thinking of using revo driveshafts, but was wondering if anything will offer more angle
also i know that having the front wider than the rear will help the turning circle, but was wondering why this happens (i'm one of those people who like to know why stuff happens :-P)
thanks guys
Old 04-04-2008, 12:58 AM   #4
anyone, i'd really like to have this done by the next comp (26th of april)
Old 04-04-2008, 01:51 AM   #5
Whats They? What are you looking for?
That should be cool. Post pic's when done.
i'm not scared of custom building stuff, because i've got about 130mm of diff clearance with clod diff centres, i've got no idea what that is in inchs because down here in aussie land we don't use it.
130mm is over 5 inches....... That can't be right? Got Pic's?
Old 04-04-2008, 01:58 AM   #6
Keep it real
Tanis's Avatar
Here's how much steering I get out of my custom Revo axles....well back off about 3* from there, as I have the hubs angled forward from the diff, so I can't quite use all the available angle of the Revo's. I did have to notch for the pillow balls to allow more travel.
Tanis is offline   Reply With Quote
Old 04-04-2008, 03:01 AM   #7
how he achevied that
no thats right, i'm getting some narrow maxx arms off a guy on here because it's 18.5in wide at the moment
thanks tanis thats exactly what i was looking for
Old 04-04-2008, 03:13 AM   #8
Well thats different and cool...... Glad you posted a Pic or I never would of though it to be true...lol
Old 04-04-2008, 03:34 AM   #9
thats the reaction everyone gives, it works awesome
and the only raise in CoG is the motor and diff gears, and then i compensated for that by adding weight down low, in all that room i now have
